Hi,
My wife acquired some old furniture including an old console system several months ago. I hooked it up to power a few days ago and found it's working but probably needs maintenance to keep it in good order. I was prompted to join as the only post I've seen on the internet showing a picture of the same receiver unit is on this forum. Looking forward to commiserating about it and seeing how other members fix and use them.
Regards,
-felipe
Hello from a Scott 2225 console system owner
felipegeek
- Junior Member
Re: Hello from a Scott 2225 console system owner
Welcome Felipe to the Hi-Fi fleet !
We anticipate seeing photos of your H.H. Scott.
Welcome, Felipe, it's good to have you here. And, please do share your Scott.
felipegeek
- Junior Member
I certainly will. Once iCloud for Windows decides it's going to sync my recent photos to my PC. It's a rather cursed piece of software.
Welcome aboard, Felipe !! It's good to have you join us. To answer your question, you can start a thread about your Scott on the "Other Consoles" board any time you'd like. We look forward to seeing your project and helping any way we can. If you have questions on how to post pictures, let me or one of the moderators know. Please refer to our "Getting Started" board for lots of helpful hints to get you started on your project
- SeniorSteve
- Full Member
Welcome Felipe! I'm the one with the "other" Scott 2225 console. I picked mine up because I didn't want it going into firewood. It had lots of problems, and was worked on several times in it's history. My gut feeling is there was a nearby lightning strike that was repaired. The console works fairly well, but I wanted a Dual changer and this had it. The changer in mine was a Dual 1209 (a replacement) that was most likely done in the 70's.
My impression is that this is a very well built console, I'm hoping you will like yours.
Steve
Steve
