Newcomb 1656 find…
- 1922VV111
Newcomb 1656 find…
I found this turntable at the swap meet for $10 I think this would be excellent for 78s! It came with a mic but I’m not sure it works yet because I haven’t plugged it in. (Probably doesn’t and they are moving this quickly to my hands lol)
It has a GE RPX type cart so I figure it’s a ground shaker when working properly but I don’t have the speakers for it.
I also found a Webcor reel to reel along with it for $10
Re: Newcomb 1656 find…
The belts in the tape deck may have turned to goo, but they aren't too tough to change. Otherwise it might work right like it is. You can't beat Newcomb for being tough. They are hard to find parts for, in my experience.
- 1922VV111
Well I haven't had a chance to mess with it yet so who knows what's going on. It came with some radio spots from the 80s on Reel to Reel, But some are meant to be played at 15ips and other tapes likey recorded with this machine from the 60s. Probably church sermons. One of them was dated 1965. Also has the Mic and Manual too. and this vintage tape head cleaner that hasn't dried out at all.electra225 wrote: ↑Tue Sep 29, 2026 1:38 am The belts in the tape deck may have turned to goo, but they aren't too tough to change. Otherwise it might work right like it is. You can't beat Newcomb for being tough. They are hard to find parts for, in my experience.
I assume both the tape deck and turntable likely was used in a church. They take very good care of their equipment.
- 1922VV111
Ok! I plugged in the Webcor and it does seem to work But whatever controls the speed is probably stuck because if you hit play the tape takes right off like it’s in fast forward! So something must be sticking that controls the speed.electra225 wrote: ↑Tue Sep 29, 2026 1:38 am The belts in the tape deck may have turned to goo, but they aren't too tough to change. Otherwise it might work right like it is. You can't beat Newcomb for being tough. They are hard to find parts for, in my experience.
No tape pressure on the capstan?
Yeah--likely from a glazed pressure roller that lets the tape slip .
- 1922VV111
"I fiddled with it....." is a common cure for many maladies afflicting old electronic equipment.......
Good job!
Good job!
- 1922VV111
The turntable works too! YEE YEE!!electra225 wrote: ↑Thu Oct 01, 2026 4:04 am "I fiddled with it....." is a common cure for many maladies afflicting old electronic equipment.......![]()
Good job!![]()
https://www.youtube.com/watch?v=Rga2KZItnLQ
Users browsing this forum: stbasil and 6 guests
