Freebe
Freebe
Post: # 20081Post hermitcrab »
Found this on FB marketplace ... they said come and get it... seeing it was 7 miles away , I did just that ... newer model with the plastikon cabinet I would say from the mid 70's at the very least I can strip out the components it says it is a RH 644 ?? I can't read it all
Re: Freebe
Post: # 20082Post William »
Not bad looking, and it was FREE!
Re: Freebe
Post: # 20087Post electra225 »
Does it work? Is it a model with the plastic turntable platter?
Re: Freebe
Post: # 20088Post hermitcrab »
electra225 wrote: ↑Fri Feb 23, 2024 8:29 pm Does it work? Is it a model with the plastic turntable platter?
The radio works, the changer not so much... the power switches on these W701 changers are cheap plastic and they strip on the metal shafts , worst comes to worst I will super glue the switch to the shaft ... but it could never be taken apart again if I do...and the platter is plastic... it uses the narrow tetrad carts like the thin armed BSR's do
so not a problem to replace it if needed , It says made in England ... just not sure if it was by BSR or Coleco :lol: I also found the model in the 1977 catalogue... model 6440 says it only has 6 watts per channel with 10 " woofer and 3.5 tweeter
Re: Freebe
Post: # 20092Post TC Chris »
Instead of stripping for parts, consider renovating and selling to somebody who wants to play LPs. After all, Bay City has a used record store, and probably Saginaw and Midland, and one more record-playing device is one more potential customer to keep the stores alive.
Users browsing this forum: Bing [Bot] and 3 guests
