I had a dual circline fluorescent fixture I installed when I bought my house years ago. It has become progressively dimmer and dimmer, so as opposed to go on another quest to find another set of lamps of the correct color, I looked for a replacement at Home Depot. They had a likely one that was continuously changing through the colors LED lamps provide. I finally found someone to ask how the light could be set for one color. She called for someone from that department to come. They didn't and 20 minutes later I left. Later on at home I went on Amazon and found a 2 pack of 12 inch ceiling lights at 2600 lumens and 5000k color. I ordered them and installing the 1 I needed was very easy. The light is brilliant. After a couple of days I connected the antenna to the old Magnavox and turned it on. then I turned on the light. It obliterated the AM band from the bottom to 750Khz (WSB).
I guess it'll be allright as long as I don't cook and listen to the radio at the same time.
My New Kitchen Light
Re: My New Kitchen Light
