We are very fortunate.....
..that we live in a "major market" radio market and have not one, but TWO decent country music stations, one on AM one on FM. 94.1 KRDE "The Ride" plays mild top-40 with traditional country mixed in. Broadcast from the reservation, it is a 100,000 watt station. 1340 AM "The Bull" KIKO is a little fleapower AM and FM station simalcast on 99.1 FM. They play traditional country with a little top-40 mixed in. We can't get the FM side down here, Mesa can't get the AM side there. The AM side is clean and of good fidelity, so it works really well with my old radios. I realize this is not a country music crowd on here, but having any decent AM station of whatever genre is rare this day and age. Most AM stations are sports or talk. We have our share of those along with Spanish and religious stations. In the Phoenix market, talk and sports in on the lower end of the AM dial, music is on the upper end. There is a fairly good classic rock station, owned by the same company who owns "The Bull." KNIX is still on the air and was once owned by Buck Owens. I don't listen to it, since they play that loud, screechy top-40 country stuff that I don't care for. I am also VERY fortunate to have a "clean" shop. Clean in the fact that I have very little in the way of interference on an AM radio. The LED lights in the shop make some noise. Those are going to go replaced by incandescent. Like in the house, "The Bull" comes in best with the radio parallel with the north wall of the shop.
Re: We are very fortunate.....
As to music genres, I learned long ago that almost all of them contain music of value and interest. (OK, I'll make an exception for rap, but maybe some day I'll change my mind about that too.).
Having music on the radio, especially on stations that pay some attention to audio quality, is good fortune indeed. My main gripe is the obsession with audience-share playlists and national feeds with no local control, input, or connection. Local stations are best. The corporate control of commercial radio is a problem. It gives us homogenized content. And all that talk....
One of these days I'll build a little AM oscillator to transmit low-power programming to my old radios. It would be interesting to see how the better ones sound with a wide-bandwidth signal, especially those with switchable bandwidth. If anybody has an especially good AM oscillator schematic, post it for us.
And finally, as to those LED lights, why not leave them and just add more for the incandescents? That would let you run the LEDs when not listening to AM radio, saving on your electric bill and AC load.
I will put two incandescents over the radio bench, but leave LED's in the rest of the shop for the time being. LED's for sure use less juice, so that is a good thing.
I have read where you guys in Michigan actually have decent radio stations to listen to. I'm not set up yet for DX'ing. I need to rig up an antenna to use with my big Hallicrafters radio for that. I have no idea what is on the radio here of nights.
I look over at my 1924 Crosley VI, a three-tube regen. set. When I bought a power supply and hooked it up one night, the first station I identified was WSM, Nashville, 700 miles away.electra225 wrote: ↑Mon Jun 20, 2022 10:23 pm I have read where you guys in Michigan actually have decent radio stations to listen to. I'm not set up yet for DX'ing. I need to rig up an antenna to use with my big Hallicrafters radio for that. I have no idea what is on the radio here of nights.
My long skinny lot runs E-W. I ran a wire from the house gable, eastward to a TV antenna mast, one end on post on the ground and the middle secured at the garage eave. It's on the north side of the lot because the AC line to my house runs from the alley to the house on the south side of the lot. The antenna can't be too near that for noise and safety reasons. Then I planted two white pines in the back yard and they thrived and now the antenna runs through a bunch of white pine branches. Not ideal for signal strength....
Does your HOA allow antennas? And does the FCC rule vs such restrictions apply to AM radio antenna wires? And if you can do it, what's the lot size and orientation? If you cannot do it, there are lots of AM loops described on the internet. I built one on a pine frame and it enhances my GE P-780 portable when listening to WSM in the winter in the living room. I can send plans.
I can't have an antenna higher than the wall. My idea is to run a wire under the shelves in the shop. Run then at a 90 degrees to each other. North and west walls. 20 feet in each direction should give me an effective antenna without going to a lot of work. My Philco 40-180 runs its internal antenna and performs just fine. I haven't started up the big Hallicrafters set yet. SX-110, eight tuber and a pretty good radio. I haven't tried the shortwave on the Philco.
The FCC rule limiting restrictions on antennas does not apply to AM/FM broadcast band antennas:
"Q: I want to install an antenna for broadcast radio or amateur radio. Does the rule apply to me?
A: No. The rule does not apply to antennas used for AM/FM radio, amateur ("ham") radio (see 47 C.F.R. §97.15), Citizen's Band ("CB") radio or Digital Audio Radio Services ("DARS")."
You can read the FCC's explanation here:
https://www.fcc.gov/media/over-air-rece ... vices-rule
The HOA will have a fit. We want to put a flagpole in our front yard. IT can't be taller than the house. The covenants in the HOA specifically address antennae and flagpoles. The good thing about our HOA is that they have made the rental next door water their lawn and do something about the moles. They made them wash the windows and screens last year. Those windows hadn't been washed since the house was built in 2008. Why we always have to live next to a dump, I'll never know. The renter is a single guy and his mom. Lazy as they can be, the both of them. They come up with $2400 a month for rent, though.
The C. Crane web site has a link to improving AM reception, including some antenna ideas. I get their ads by email but just search on C. Crane. They also have some AM interference-hunting suggestions (battery radio, turning off al breakers, etc.).
My lawn probably looks like your neighbor's. I don't much favor encouraging it too much. You just have to cut it more. Everybody around here has put in sprinkler systems and hired lawn guys. Me, I cut my grass (etc.) myself when it's getting close to city-citation height. I've got boats, cars, and a job to worry about, and lawn perfection is way down on the list. Down there with having teeth pulled getting the next colonoscopy, or playing golf.
Maybe you could try a straight wire antenna under the eaves like mine. Do they face east west ?
Eaves are on the north and the south sides. Both table radios and consoles receive 1340 AM with their butts toward the west wall. I don't know about the loopsticks in the Magnavox stereos yet.
One of those simple lead in wire dipole antennas tacked up in the attic could work for your FM.
