Another RCA
Another RCA
https://www.facebook.com/marketplace/it ... e_search&r
located in Detroit area is this a good price?
Re: Another RCA
I don't have a Facebook account, so it won't let me see it.
Re: Another RCA
Good for you ... I think FB is a waste of time .. I only use it for the marketplace here are a few pics... they are asking 100 bucks
Re: Another RCA
I have the same unit only my has the Blonde finish. I found mine in the local junk store, and, it's not pretty. There were even mice living in it. There will be others that will probably know, but, I think this was in the middle of RCA's pecking order.
Is it going to follow you home, Elton?
Re: Another RCA
well that depends.... Bill, since you got one can you tell me some of the specs?
Re: Another RCA
Thanks, Elton for the pictures. $100 doesn't sound too bad to me for something that is nice as that one. It's only money and you can't take it with you. Might as well rescue a console and have some fun with it. Good luck.
Facebook is something that never interested me. The wife keeps up with family and friends and that on Facebook, but it's too gossipy for my taste.
- chazglenn3
Re: Another RCA
I quit Facebook back in 2016. The only thing I miss is access to the Marketplace.
Charles
USAF Veteran
USAF Veteran
- back-2-mono
Re: Another RCA
That's a very nice SHF-4 with the rare factory installed tuner, in mahogany.
PP, 6V6 amp, dual 12 inch woofers and a pair of 3.5 inch cone tweeters on angled horns. Standard work-horse RP-205 record changer with a Sonotone cartridge rounds out one of my favorite and sought out RCA's.
If it were in SoCal, I would have snapped it up in a heartbeat..sigh
Re: Another RCA
I still have the account... but never look to see who posted the latest crap on line , just the marketplace is all I get on it for , because in my area Craig'slist has seem to fallen from favor and not much get posted anymore ...I think the people are willing to deal.... lets see what I can do...
Re: Another RCA
Sorry, Elton, I'm just checking the forum this morning. What Back-2-mono said is about it. After I got it I did some research. There were several articles I found about the amp in these RCA's. Some said they were a nightmare to work on, others were ok with it. Mine is still sitting in the barn where you picked up the RCA stereo theater. The only thing I have done to it was to pull all the guts out of it, scrub it about 5 times to get the smell of the mouse house out, and then put it back together. The electronics will be the easy part, the cabinet will take a lot of work which is one of the reasons it is still sitting in the barn. I too have the optional tuner, and, mine came with the optional matching speakers to make it stereo. I paid 10 bucks for mine, but, that is about all it was worth the way I found it. From what I read, once done, the are good performers.
Now that I'm looking at my photos, I think mine is Maple not blonde.
Re: Another RCA
That last photo of the innards prompts me to wonder (again) why, with all that real estate in the back of the unit, they had to mount the power amp right up under the record changer. Didn't they care where the heat went? I know, dumb question. Of course they didn't. My '48 Wurlitzer has a slanted shelf over the amp. It has two functions. One is to shunt the heat out the vents at the back. The other was likely to keep oil from the record selection and turntable mechanism from dripping onto the amp. On a commercial-grade device, they attended to heat issues (etc.).
Re: Another RCA
I offered 50 bucks because they admit the TT does not even work... they countered with 75 ... it is a 100 mile ride ... if it were closer I would consider it , but with the cost of gas now... it would still cost me 100 + bucks when all said and done ...which I told them ... think I will pass
Re: Another RCA
Probably a good idea, Elton. I told myself when I retired I wanted to learn how to repair vintage electronics. I'm new to this game compared to most of you, a greenie so to speak. The other thing I told myself was not to get too carried away spending lots of money one the units I wanted. So far, I have held to that. The highest I have paid was $110.00 and that was for the Magnavox Berkshire. The next two were VM's at $100.00 each. Everything else was below, all the way down to free. Which is always the best price.
Now, my following in life as always been, don't be in any hurry to buy something. If you hurry, you usually regret it later down the road. And, if it's something you want, when the time is right it will fall into your lap. That has happened to me more that I can count in my life.
Re: Another RCA
Real nice unit back in the day, well worth the effort. That one needs stripped down completely, the woodwork and cloth redone, and put back together after the guts are refurbished. A big project.
Re: Another RCA
Roger, that's why it's still sitting in the barn.
Re: Another RCA
If you use a mix of 50% lacquer thinner and 50% acetone, the old lacquer will wash right off. And it is not prone to removing the stain as bad as stripper does. Putting on the new finish is the easy part. Getting the wood clean and getting the tone right is the work. I took the ST apart as far as I could take it, refinished it and put it back together. Hugely satisfying project.
Re: Another RCA
Do you add some sort of thickener for vertical surfaces? Have you tried this on thicker finishes, like multiple layers of paint or varnish? The hardware-store paint removers have been made so safe that they won't harm painted surfaces.
Most furniture finishes are quite thin, and maybe would not require so much sitting of the remover. My boat work, though, is usually on surfaces with years of annual varnish. Each year I sand some, both for surface smoothing and for buildup-reduction, but eventually I'm dealing with thick layers of petrified resins. Now that the consumer-grade products are useless, I'm on the lookout for something that works.
Re: Another RCA
Paint strippers were formulated with dichloromethane (common name is methylene chloride) and worked pretty well but were super unpleasant to use, don't know if available still. If the finish isn't too heavy I tend to try to get it off by sanding as much of it as I can.
Re: Another RCA
Well,the choice was between unpleasant stuff that took finish off, and pleasing stuff that kinda sat there. One of my sailboats had a mystery interior finish inside that peeled off in big curls when it wanted, but stuck tenaciously when it wanted to stay. I decided to remove it. Because it was in an enclosed space and I was the laborer, I started with one of those "friendly" orange citrus removers. No effect at all. I moved to the gentle version of Zip-Strip. Not much better. Then the middle grade of Z-S. Same. Then I bought the all-toxic, all the time version of Zip Strip and it worked. I would come up for air, take a big gulp, and head below to scrape. I was probably fooling myself, but self-deception often lets us a get a job done. Those last 3 were varieties of methylene chloride removers. A year ago last fall I tried removing varnish from the other boat and mostly ended up exercising my vocabulary !!!. Eventually I got it off but only after finding a can of meth. chlor. remover to get things started.Firedome wrote: ↑Tue Mar 01, 2022 1:39 pm Paint strippers were formulated with dichloromethane (common name is methylene chloride) and worked pretty well but were super unpleasant to use, don't know if available still. If the finish isn't too heavy I tend to try to get it off by sanding as much of it as I can.
Re: Another RCA
The lacquer found on radio cabinets is not in very good condition by the time refinishing is necessary. Almost any compound known to man is a natural enemy of lacquer, hence my propensity to use polyurethane. I like to buy some sauce to reduce the flash (evaporation) time of the lacquer thinner and acetone. If you don't use something to slow down evaporation, it can take a lot of material to get the wood clean. I put a bit of the mixture in a stainless steel parts pan, the use 000 steel wool to remove the finish. I use a small pad of the steel wool, and rub with the grain. Wear appropriate gloves that are chemical resistant and have plenty of cross ventilation. Many times, paint is applied right over the old lacquer finish. I take a screwdriver and scratch thru the paint in one spot, then use my refinishing mixture. It gets under the paint and removes both the lacquer and the paint. End grain is a problem if the cabinet has been painted. Many times removing the paint from end grain is not totally successful. This is why they invented flat black paint. Then apply poly over the whole cabinet to make the gloss the same level. When I get the wood clean, I like to use three wash coats of shellac, sand, then a couple good flow coats of shellac, then prep for the final finish. Shellac will seal all the boo-boos and will eliminate fish eyes and orange peel.
