All I can say is #$%*&!!!
Post: # 249Post TC Chris »
Yesterday in the town where the Chevy lives I drove the Mustang to switch cars. Backed out the Chevy and went to put the Mustang in and... coolant under the car. Seemed to be from a heater hose. But the looked really hard to get to. The local auto parts place ordered them up and I picked them up today. Getting the old ones out and making the new ones fit...#$%*&!!!. That's all I can say. The car is out sitting after couple mile drive to my sister's for internet service. Well see if that fixed it (and if I avoided busting the heater core when getting the hoses off).
Re: All I can say is #$%*&!!!
Post: # 250Post hermitcrab »
When I was younger I had a 65 SS impala with a 327/ 4 speed ... loved that car... I had a heater hose leak so as carefully as I could twisting the hose to break the seal on the heater core nipple and snap... right off the heater core .... talk about a *&%$# moment fortunately it was not that hard to access the core , I just hate standing on my head under any dash... :x
Post: # 251Post Hydrolastic »
Hello. Not to diminish your pain. The British cars i work on the heater cores break when you remove the hoses if not then they break when you remove the heater boxes. If not then, when you remove them from the heater boxes. The new ones then don't fit. When finally installed, they break putting the hoses on and after that they break just from the weight of the hose itself. Also of course nothing on a british car lasts more than ten years. So your kind of lucky . Hydro
Post: # 252Post electra225 »
I have replaced HUNDREDS of heater cores. The absolutely worst one I ever messed with, and I did several of them, was the 1963 thru 1965 Buick Riviera with factory air. They put the climate controls system on a box at the factory, then built the Riviera around it. :shock:
I would concur with your choice of adjectives describing heater cores and leaky coolant. I couldn't have said it better...... ;)
Post: # 256Post walyfd »
And the original clamps were the spring type. The most horrible design of all time...
Post: # 261Post William »
Greg is so correct with his statement about heater cores and Buick Riviera's. I just do not know what Buick was thinking when they designed the car around the heater system.
I have had pretty good luck cutting the hose off just past the heater core nipple, then taking a hacksaw blade and carefully cutting the heater hose that is still attached to the nipple and then carefully pealing it off. Of course this all depends on accessibility to the heater core and it's hoses.
Post: # 269Post TC Chris »
My Mustang had original clamps on the firewall end, good clamps for clamping but terrible for removing. I was able to pry one open with a screwdriver and slide it off, but the other one would not budge. I finally managed to snip it (slowly) with diagonal cutters. With the clamps gone, I could slit the hoses at the nipples. The engine ends had the screw-type clamps and they were easy to remove. All this was in a very confined space between engine and firewall and with all manner of cable and AC hoses in the way. #$%*&!!! Then the new hoses were not exactly the original shape so I had to improvise on the position. No leakage so far. But I'm carrying caps for the engine nipples and extra antifreeze just in in case.
Post: # 272Post electra225 »
I have a Snap-on tool that is the berries for removing any type of spring ring type of clamp. It sort of bends in most any direction. I've never had a clamp on any car that I couldn't remove with this tool. I found a way to hide screw-type clamps under the climate control on my Buick so I didn't have to use spring ring clamps and so the judge's couldn't find them.
Post: # 279Post TC Chris »
On the Mustang, Ford used a screw and nut that tightened a band around the hose. Unlike the current screw-type clamps, those did not release when you backed off the screw and nut. They were permanently stretched in place. One-way devices.
But I drove the Mustang home tonight after some test drives showing no leaking coolant. I'm nervous about that because the coolant temp gauge has failed. If the serpentine belt breaks, the only ways to detect the problem are (1) look at the ammeter for neg. charge; look at oil pressure for a drop from high temp; or listen for the sounds of an overheated engine. I bought a Bourdon tube temp gauge but don't have a place to put it in the cockpit. In any event, the Mustang made the 140-mile trip home with no problems.
Post: # 286Post 19&41 »
They make relatively small LED UV flashlights that are helpful in locating leaks. You can find them on Ebay. My late mustang had a heater core that you had to remove the dashboard to replace. My current Explorer had a thermostat housing made of 3 pieces of plastic. It introduced itself to me by covering the engine with coolant. I replaced that with an aluminum housing.
Post: # 288Post TC Chris »
I'm wondering if the heater hose has been slow-leaking for a long time at highway speeds. I'd fill the overflow container to the cold-fill line and after a trip it would be empty after cool-down, when the radiator should be sucking it back in. My recent theory had been that it was a leaking gasket in the fuel-injection throttle body assembly, which has a coolant line through it (not sure whether it's to warm the area or cool it). Apparently that's common in Mustangs of this vintage. It would explain why there were no visible leaks, no coolant in oil (thank goodness), and no other explanation. I had rounded up the gaskets this winter. Now maybe I will wait and see what happens.
Post: # 291Post electra225 »
What engine is in your Mustang? Some of the V-6 Ford engines suffered from a leaky intake manifold gasket if equipped with an aluminum intake manifold. I have changed lots of head gaskets on them as well.
Post: # 326Post TC Chris »
It's the 5-liter V-8. In 1987 the Detroit Free Press carried a review of the current Mustang GT. The author wrote that if you wanted an American V-8, you'd better buy a Mustang quickly because the V-8 was on its way out. I headed to a dealership but the cost of admission was way beyond my budget. Then in '88 I found my '86 in the used car section of the classifieds. Fuel-injected V-8, 5-speed, T-tops, and it was the color cars are supposed to be, red. We struck a deal. It has been in my care since.
Post: # 334Post electra225 »
That little V-8 has been around since the 1960's and was not only one of Ford's best, but may arguably be one of the best engine designs ever. Compact and sturdy, capable of gobs of power. Ford messed up when they quit building it.
My grandfather had NO use for the Ford flathead V-8. None. Zipkus. If you were driving a Ford V-8, you parked at the mailbox and walked up the driveway. He didn't want one on the place in case it broke down and he'd have to work on it. He liked Buick and Packard straight 8's. He was a closet Chrysler flathead fan, both the sixes and straight 8's. The big 324 Chrysler straight 8 had a moniker, "Thunderbolt" maybe?. Grandpa liked those big flatheads to power boats. Chris Craft used lots of them in their boats and Wards, yeah, THAT Wards, used them in farm tractors. The six cylinder Chrysler Industrial engines were used commonly in farm equipment. Both were tough, reliable, relatively fuel efficient powerplants. They sounded wonderful with a straight pipe.
Post: # 336Post 19&41 »
Those Chrysler engines got around. Here is another use they were put to.
https://www.youtube.com/watch?v=IAMiTfSU7ZA
Post: # 337Post electra225 »
There was a fire alarm mounted on a trailer at a car show I attended years ago. It was powered by a 354 Hemi.
Post: # 342Post TC Chris »
electra225 wrote: ↑Thu Jul 22, 2021 2:53 pm TMy grandfather had NO use for the Ford flathead V-8. None. Zipkus. If you were driving a Ford V-8, you parked at the mailbox and walked up the driveway. He didn't want one on the place in case it broke down and he'd have to work on it.
I'm a huge Chuck Berry fan. Take Maybellene, a great song. Quoting:
As I was motorvatin' over the hill
I saw Maybellene in a Coupe de Ville
A Cadillac a-rollin' on the open road
Nothin' will outrun my V8 Ford
The Cadillac doin' about ninety-five
She's bumper to bumper, rollin' side by side
Maybellene, why can't you be true?
Oh Maybellene, why can't you be true?
You done started back doin' the things you used to do
The Cadillac pulled up to a hundred and four
The Ford got hot and wouldn't do no more
It then got cloudy and started to rain
I tooted my horn for the passin' lane
The rainwater blowin' all under my hood
I know that I was doin' my motor good
Somebody pointed out that he knew what he was talking about--the Ford flathead V-8 was prone to overheating. But then, so was the Buick straight-8. It's just cool that Chuck Berry knew what he was writing about.
Post: # 346Post electra225 »
And Clyde Barrow wrote a letter to Henry Ford, congratulating him on the Ford V-8. Clyde pointed out that he stole a Ford V-8 every time he had the chance. He and Bonnie died in one. He could have died the second time if he had driven a Ford flathead V-8 up grandpa's driveway....... ;) :roll:
Grandpa could fix just about anything. He had his head handed to him by working on a Ford V-8. He did a valve job on one. He never did get the valves set right. There was a procedure for adjusting the valves unique to that engine. Grandpa didn't know that little trick. His buddy Morris straightened it out, but grandpa never forgot that. And he refused to work on another one.
I had a good customer when I had my restoration shop. I did a '40 Pontiac for him. He drove his dad's 41 Ford coupe, still does. He came in one day with the steam rolling out of the hood. I told him not to bring that thing into my shop, I did NOT work on Ford flatheads. To make a long story short, I redid his '41 Ford. The overheating was due to a faulty temp gauge, allowing the engine to overheat chronically. The engine was not rebuildable. We got a new reproduction engine from Dennis Carpenter, complete. All we added was the intake and ignition system. WE got a 255 cid engine, which is really either a Mercury or a Ford truck engine for 1941. We put in an Ignitor ignition system, along with a dual-voltage, dual-polarity electrical system. The engine we used had aluminum heads. Ford used a torque tube drive in 1941, like Buick did. On a Buick, when you remove the engine, you have to remove the torque tube, transmission, then the engine. On a Ford, you never mess with the torque tube. If you need to replace the clutch, you remove the engine! When I learned this, I was shocked. But, on a Ford flathead, they use a thick-spline setup. You just have to get the engine CLOSE, then give it a big kick with your foot. The thing will slam into place like it's on rails. That was the slickest setup I had ever seen. Going from a 221 cid engine to a 255 gave the old girl some extra grunt. We put on dual exhausts and glass pack mufflers.
Post: # 355Post TC Chris »
electra225 wrote: ↑Fri Jul 23, 2021 3:19 am I had a good customer when I had my restoration shop. I did a '40 Pontiac for him.
Any suggestions for a Buick restoration shop in or near Michigan? I've been giving thought to having my '38 done--not to show condition, necessarily, but to driving-around-and-looking-good condition. At 74, and having owned the car since 1966, maybe I'd better hurry up a it.
Post: # 362Post William »
Actually Chris, there is a body shop that does do vintage vehicles in the Hart area. I have no idea how busy he is, but I can check and let you know?
