1960 Admiral "The Allante" Way Cool Console
Post: # 4414Post Hi-Fi-Mogul »
Hi all,
I just happened across this Admiral, and its
very hip design.
Never seen one, but this one sounds super.
https://www.youtube.com/watch?v=cNizz_hMcRw
Re: 1960 Admiral "The Allante" Way Cool Console
Post: # 4415Post walyfd »
That is cool... nice looking unit, too.
Post: # 4416Post Firedome »
Nice amp but odd how Admiral uses the Euro nomenclature of EL-84 for 2 output tubes and the JEDEC name 6BQ5 for the other pair. Wonder if they sourced or spec-ed them differently too? No obvious reason why they would as their all just 2 sides of a push-pull pair. I prefer to use the US name as the 1st 1 or 2 digits do actually tell you something about the tube.
Post: # 4423Post electra225 »
Did anybody get a good look at the changer? He closed the door before I could look at it really well. That's a nice looking console.
Post: # 4424Post William »
I wonder if that was an Admiral built changer? The leveling arm looks VM, the tone arm head looks a little like Garrard, and, the controls look similar to the Zenith's of that era with the Cobra tone arm. Nice looking unit, and, definitely a TOTL model.
Post: # 4426Post electra225 »
I remember Ken saying Admiral built their own changers. I just never seen one like it before. I believe that is the same amp as the one my uncle had. His was a 1963 model.
Post: # 4427Post William »
That's right, Ken just recently posted the lineage of changers. Thank you Ken! I need to copy and past that somewhere in my computer where I can't find it when I want it. :roll: :(
Post: # 4428Post Hi-Fi-Mogul »
The record changer is an Admiral RC607 series,
per the photofact.
I slowed down the playback, and you can just
see the classic Admiral controls on L/R sides of the base.
It does look similar to a V-M, but the mech seems
simpler underneath.
Post: # 4429Post TC Chris »
Firedome wrote: ↑Thu Jan 06, 2022 5:43 pm Nice amp but odd how Admiral uses the Euro nomenclature of EL-84 for 2 output tubes and the JEDEC name 6BQ5 for the other pair.
That was exactly my response. At first I thought it was a single-ended amp but then I saw "EL84" and thought wait... that's a 6BQ5. Two of them. Maye that's how they keep the L and R channels of the amp labeled....
Ken Doyle
Post: # 4442Post Ken Doyle »
electra225 wrote: ↑Thu Jan 06, 2022 9:20 pm Did anybody get a good look at the changer? He closed the door before I could look at it really well.
The plastic bezel surrounding the control levers is the same as the earlier Admiral RC600. The later changers were 4 speeds, which accounts for the left lever sitting in a different position.
admiral rc600.jpg (22.27 KiB) Viewed 2131 times
Post: # 4445Post hermitcrab »
Those swivel speakers are cool!
