Sears Silvertone table radio, model 5021
Post: # 30274Post William »
I have been working on a Sears Silvertone table radio that was built by Arvin for Sears, chassis number 132-80001. It came in two model, 5020 which was a walnut plastic case and model 5021, the one I have, which came in a wood Early America maple cabinet. This was definitely a TOTL radio for Sears, having 8 tubes, a 5X7 woofer and a tweeter with crossover cap. It sounds quite good when it works. The down side of this radio, it has a PC board. Tube layout as follow:
17C9, 18FX6A, two 18FW6A's, two 18FY6A's, 50C5 and a 50HK6. No rectifier tube, it uses a diode as the rectifier.
Here's the odd part. The 50C5 is an audio output tube which makes perfect sense. The 50HK6A is also listed as a audio output tube. Both tubes are shown as audio output tubes in Sam's and on the tube chart in the radio. The schematic shows them in PP, I think, but how does that work with them not matching in number. I checked, and they do not sub for one another yet they are both used in the audio output circuit for this radio.
So, this radio had the "HUM", OK, I replaced the filter can cap with three component caps and all was well. NOPE, that did not fix the hum. Hmmm... I poked and prodded and discovered a bad solder joint at a resistor that I did not touch. Soldered that, and it worked until the next time I turned it on and the hum was back. Again, poked and prodded around and found another bad solder joint, and then another and another and another... After soldering a lot of connections it seems to be working but I almost hate to put it back in the cabinet, afraid the jarring of the PC board might cause another open contact. Moral of the story, be careful when you remove a 60 plus year old chassis in a radio with a PC board. Apparently the radio does not like that.
This is the radio:
https://www.radiomuseum.org/r/sears_roe ... _5021.html
The Sam's is 696-10. When I first started working on this radio I could not find any info on it. About month ago I started looking again and found the above link but no schematic. I kept looking and eventually found someone on ARF that included the Sam's.
https://antiqueradios.com/forums/viewtopic.php?t=276254
Go all the way to the end of this thread and you will find a a PDF that will open so you can see the schematic.
If anyone can explain the different audio output tubes I would love to know.
Re: Sears Silvertone table radio, model 5021
Post: # 30276Post electra225 »
I'm not sure I understand why they used two different output tubes. Admiral and GE liked using 50HK6, 50HC6 and 35GL6 output tubes that nobody ever heard of and nobody else used. This radio uses low-filament-amperage tubes. There is a 5.2 ohm hum-bucking coil on the HK6 end of the output transformer. You might check to see it isn't open. My guess is they used two different output tubes to control hum, but I wouldn't swear to that in court....
Also check to see that one half of the output transformer primary is not open, that you have actually a P-P output rather than single-ended. One of those output tubes may not be working, which can cause a hum. Verify this by checking B+ at the plates of both output tubes. Is the hum controlled by the volume control? Do you have the 18FY6 and the output tubes that you can sub?
Post: # 30282Post William »
Actually, after pretty much soldering just about every connection on the PC board it is playing just fine. I slipped it back in the cabinet and it still plays. The next test is putting the back, back on. That is usually the death step. :roll: :shock: :lol:
Post: # 30283Post electra225 »
Good job. .... :D
danrclem
Post: # 30285Post danrclem »
I have confidence in you Bill and believe you have it permanently fixed.
Post: # 30287Post William »
Thanks, guys, but I am not out of the woods yet. Stay tuned!
Post: # 30294Post William »
Yup, as my luck goes, back installed on the cabinet and the hum is back. :shock: :( Here we go again!
Post: # 30295Post electra225 »
Does that cabinet use an interlock on the power cord?
Post: # 30302Post William »
Yup!
Post: # 30303Post William »
Yup!
Post: # 30306Post electra225 »
Since it always possible that something weird, out of the ordinary, may be going on, I asked about the interlock. Might it be possible that the interlock which is fairly rigid in the back, might be flexing the PCB enough that it is breaking a trace to the filter caps. You might take a good look at the traces and connections around the rectifier and filter caps. The heat from the rectifier might burn some of the traces. IT's worth a look at least.
Post: # 30308Post William »
I actually thought of that. After 60 plus years of heat and flexing it is a wonder it works at all. The PC board sags a little
in the middle which is where the interlock is located. The 2 output tubes are located to the left. I will get back to it sometime this weekend.
Post: # 30310Post electra225 »
Bell wire makes good wire for hardwiring a printed board. Not all that tough, just tedious. The GE stereo I did for Don had about half the amp chassis hardwired and it's been running just fine for at least ten years now. My problem with running traces looking for a breach is something my eyesight is not good enough for anymore. Hardwiring is usually more successful than trying to resolder connections. Heat is likely what caused the breach, more heat from a soldering iron usually doesn't help any. Good luck....... ;)
Post: # 30325Post 19&41 »
When you resoldered the connections on the board, did you resolder only the actual joint where the component leads passed through the board?
Post: # 30326Post William »
Sort of, but the solder did run over the actual connection. I have been trying to work on it today but keep getting disturbed. Maybe after supper.
Post: # 30328Post 19&41 »
I've worked on a lot of discrete pc boards over the years and I found that if i would remove the coating from about 1/4 inch of the trace from the connection and drew a solder gusset from the trace to the connection, a good wet gusset, that would bridge many a problem fracture. In most cases the boards were acid etched and even with coated traces it would make the traces brittle over the years and the eyelets were the first to break from the trace, microscopically in many cases. The trace repair area must be cleaned well, fluxed and heated just enough to do the job. I would recommend tools such as these to do the cleaning before soldering. https://www.ebay.com/itm/398263002105?_ ... R4Sku4H9Zw
Post: # 30329Post William »
Thanks, Rex, that is most helpful. The funny thing, it is working!!
I thought it was repaired, until I put it back in the cabinet. It was even playing in the cabinet, until I put the back on and then the kiss of death struck. While acting up in the cabinet, I started to poke around with my plastic thingy as it warmed up, which was pretty fast, the problem just faded away. Hmmm! I shut it off and waited until the next day to try again. This time the problem came on with full force and did not go away no matter what tried. Back to the bench, pulled the chassis, plugged it in, turned it on, and it is playing just fine. I am listening to it as I write this.
The FM-RF, amp-FM conv, tube is a 17C9. Testing it on two different tube testers it has shorts and on one tester it shows gas. The 50HK6, one of the audio output tubes, also shows a short but no gas and tests good. Should I be suspicious that the 17C9 could be the problem. With it now working, I took my plastic thingy and wiggled, pushed, moved, and did everything I could think of to make the PC board show a sign of where the problem might be. NOPE, not going to happen, it just sits on the bench singing happily away.
Post: # 30330Post electra225 »
I have a Motorola stereo that has a 17C9 in it. Those are ten-pin tubes in a nine-pin socket. Have you tried wiggling tubes and moving the chassis in a totally darkened room? You might be able to see a little spark where the bad connection is if there is one. Does anything look darkened or burnt? Maybe it will be healed if you don't put the back on it........ :roll:
I don't get too excited about shorts unless it is an H-K short. I have a Stromberg-Carlson 1121 that plays just fine. One of its 6V6G output tubes has a nice blue glow around the base of the elements after it's run for about two hours. That tube is gassy, but it still works fine and it is really cool to see the blue glow.... ;)
Gas and shorts can be fatal to a picture tube..... :o
danrclem
Post: # 30337Post danrclem »
If it's a bad joint on the pc board some freeze spray or electronics duster might help you find it. The electronics duster needs to be held upside down for it to freeze.
Post: # 30338Post William »
Thanks, Danny, I thought about that but I need to remember to pick some up. :roll: :(
