RCA changer
RCA changer
Post: # 3369Post William »
I finally got around to taking a couple of photos of my RCA changer. Greg mentioned that RCA built their own changer starting in 1953. That would make this an RCA changer since it goes in my RCA stereo theater from 1966-67. It's interesting how similar they look to the VM design.
Re: RCA changer
Post: # 3372Post hermitcrab »
exactly the same changer I have been looking for , but they usually don't get separated from the consoles under normal circumstances , except mine....most likely I will end up buying a a console just to get a changer and strip the rest out for parts.. :( ...as far as the mechanism under the deck... I think VM set the standard for changer mechanisms .. and others just copied it...
