Restuffing can caps
Restuffing can caps
Post: # 28874Post TC Chris »
Here's a link to a short piece in restoring a Fisher tube FM tuner, with good pix in restuffing can caps and replacing a selenium rectifier. And then he discusses safety caps, always a good discussion.
https://philcoradio.com/library/index.p ... storation/
He did a good job. And as a side benefit, you can check out his tips on restoring old Philcos.
