Symphonic 1260 & 1747
Re: Symphonic 1260 & 1747
I like that the mono unit gave a choice of playback compensations--78, flat, RIAA. Odd that they didn't give a choice of "Col" or Columbia--Columbia used a compensation curve that makes them sound lousy on modern, RIAA-only devices.
Somewhere I read that ceramic cartridges had a response characteristic that made them play RIAA back without a need for electronic compensation.
The mono unit is definitely higher end, the cabinet gives it away.
What do they sound like?
I don't like to power them up on the original electrolytics. While going through the mono amp a bad audio transformer was discovered. A donor replacement 6L6GC transformer from a Bogen DB-15 mono block is going in the little symphonic amp. A member here Who likes Motorola's is helping me with the transplant
Haven't gotten to the 3 channel yet which is single ended 6bq5
- 47D7CF59-23E1-4693-BC2E-7C5CBC7F48BB.png (719.05 KiB) Viewed 27394 times
Wow, that's a substantial amp. I had always thought of Symphonic as a cheap, low-end brand.
Did Symphonic actually build that amp, or did they farm it out to somebody else? I agree with Chris. I always thought Symphonic was a low-end brand. Nothing low-end about the looks of that amp.
Believe symphonic made it
The rest of drawings are in the downloads section
Wow is right, those transformers look something Fisher and Mac would use.
