Car work before winter
Post: # 3112Post TC Chris »
As usual, I'm trying to squeeze all the to-do projects in just before snow & holidays. I decided to get a new top for the Chevy; if you have a convertible, it's nice to be able to run the top up & down. The same guy will stitch up my upholstery seam. But the top is a 10 to 12 week order, so it will probably be next spring. Meanwhile I've found a winter storage spot for the car, right next to the '65 Olds. "I made a space next to your Olds so they can sit together," said the guy who owns the storage. Think he likes cars?
And the Mustang went into a shop next door to my new office. The parking lot was filled with cool vehicles--a '65 Mustang, an Isetta (!!), a variety of English and German older cars, some old trucks and some modified ones. That looked like the kind of place that would be happy to work on an old Mustang. The steering had a hard bump right in the middle, and they confirmed that it's what I feared, the steering rack. They'll figure out why the other shop couldn't bleed one brake caliper. And they found the water pump weeping, so that gets replaced. But the rack has to be ordered. There are 4 possible versions for that year Mustang. So decided to bring my car home to be snug in the garage while snow flies tonight. They said "we can do it next spring if the weather gets really nasty." I had biked to work this a.m. but the bike fits into the back of the car so I went over and loaded the bike in. I was going to get in and start it but noticed somebody lying under the front of the car. It was the service tech, measuring the bolt spacing on the rack just to make sure. Always look first.... But when I hit the ignition, nothing. The back hatch tends to pop open randomly and I'll bet the dome light ran the battery down. The guy brought out the portable power and it fired right up.
And back to the Chevy. I need a vacuum modulator for the cast-iron Powerglide. The transmission shop got one but the threaded nipple is the wrong size. Any suggestions for finding old transmission parts? I haven't looked yet. The wrong one is sitting right here so can measure what doesn't fit (too big).
This weekend the truck needs the oil changed--best to do it before winter is permanently here and the hands are cold and clumsy and painful. And maybe get the snow tires on, if the tire shop gets the leaker snow tire repaired tomorrow. "It'll probably be next week" was the advice on Wednesday a.m. I'm hoping I'm not out in the driveway doing it next Wed. p.m. just before leaving for Thanksgiving. Why didn't I take it n two weeks ago?
Re: Car work before winter
Post: # 3113Post electra225 »
There is an outfit that advertises in Hemmings. Northwest Transmission, IIRC. They have obsolete Dynaflow stuff, like reverse anchors. You might get a Hemmings and see if you can find them. Northwest or Northeast Transmission. It's been awhile since I was in that business and my "remembery" is not as good as it used to be. Powerglide stuff shouldn't be that tough.
Post: # 3114Post walyfd »
Also try FATSCO in NJ. https://www.fatsco.net/
I've been doing a lot of little things on the '62. Installed the guidematic which means the dash pad is finally on the car again but then I found a cluster bulb had burned out... off comes the pad...
Still waiting for tires (promising end of Nov) and the belts I ordered 3 months ago.
Winter project is to get the front seat out so I can restuff it.
Post: # 3143Post TC Chris »
OK, Fatsco shows the vac. mod. for the '58-'62 cast-iron Powerglide so I e-mailed them to inquire. They show a 1/2" thread. My one that is too big measures 5/8" thread to the outside of the threads. Are pipe threads measured to the outside of the cut thread or the inside?
And then I went out to change the oil in the Ranger. Got the filter off and replaced. Then tried the drain plug. @#*&%!!!!, the 13 mm socket started slipping. Tried the Vise-Grips. No luck. Went to Ace Hardware; the only 13 mm 6-point socket they had was a 1/4" drive. Tried that but it slips out & off too. %*&$#@!!! Guess I'll have to pay a shop to run it up and remove the plug. I went to the auto parts store and bought two new drain plugs--one the original 13 mm and another 16 mm that seems a bit less dainty. I also bought a 13 mm box-end wrench but it slips. All this happened because the place the replaced the rear seal in my transmission after they replaced the u-joint also changed the oil. My best guess is that a service tech pulled the wrong plug. They didn't tell me they had changed it--I knew it was almost down 1 qt. so I pulled the dipstick and found clean oil after 6,000 miles. But my best guess is that they really torqued the drain plug on, something I never do for the obvious reasons.
Post: # 3145Post electra225 »
The instrument clusters, or the idiot light cluster, on my Buick just turns a quarter turn to the left and pops out so you can change bulbs and get to the back of the speedometer if you need to work on the cable. The clock does the same thing. 1963 was the first year for a plastic instrument panel in a Buick. Grandpa near fell out when he heard they were going to put plastic instrument panels in Buicks. And they were going to use Delcotron generators, which would be easily damaged and will only cause trouble. And the last year for Dynaflow. Who would buy a Buick without Dynaflow? Of course, he said the same thing in 1953. Who would buy a Buick without a Straight 8.....
Ain't it amazing that you can find car parts on a stereo console forum?
Good luck with the installation of your Guidematic. Where do they stash the amplifer chassis on a Cadillac? It's under the glove box on my Buick. Do you use LED lamps in your instrument panel?
Chris, they made a doodad (Snap-on) made especially for stripped heads on Ford drain plugs. Yours is not the first one, trust me. It has teeth on it like an oil filter wrench. You put it over the outer lip of the drain plug and it takes it right out. The more you twist it, the harder it grips. I had both the 3/8 drive and half inch drive versions. Some of the diesel drain plugs were real happy where they were.
Post: # 3151Post walyfd »
Don't forget cadillac used dynaflows in '53 after the hydramatic fire. I've seen 2 in 30 years in the cadillac club...
The guidematic amp is in the left cowl next to the parking brake behind the carpet. I can hear it cycle which I never heard a sound from the autronic eye in the '57... except for the vibrator... with the relay so close to the driver's seat, I hear the click-click. I think Chevy had theirs in that spot, too. Actually cowls were pretty standard across the GM line starting in '59 and guidematic was available as a dealer-installed option.
Other thing I did today was drill the drain hole in the resonator.
Post: # 3155Post TC Chris »
I've got a little pipe-wrenchy thing called a Masterwrench from Heller Bros., an antique of some sort. One fixed jaw, one pivoting so it works like a pipe wrench. But I'm tired of lying on the ground under the truck, and it's my daily driver that I don't want to get un-driveable, so I'm going to se if the shop next door to work (the ones who are working on the Mustang) can squeeze me in for an emergency fix.
I did not grab it with the middle section of the Vise-Grips, just the tips, because I didn't want to mess it up further. Maybe a small pipe wrench?
But back to pipe threads for my vac. mod.--the one that doesn't fit has threads measuring 5/8" outside. Fatsco sells one they call 1/2". Mine would be 1/2" if measured in the valleys of the threads. How are pipe threads specified?
Post: # 3159Post walyfd »
Call them on Monday. Can't remember the guy I talked to but he was nice and knowledgeable. Even offered to rebuild the '57 trans if I could get it out of the car and deliver it to them. They're a go-to for us in the upper east coast. What I couldn't find from Northwest. I found at Fatsco.
I'm sure if you ordered something and it didn't fit they'd take it back...
Post: # 3160Post electra225 »
There is a man in our local Buick club who owns a '53 Coupe DeVille with a Dynaflow in it.
A 1/2 inch NPT (pipe thread) is a totally different kettle of fish from a 1/2 inch SAE bolt.
Post: # 3189Post 19&41 »
I have 3 sets of metric sockets and only one in the 3 sets fits my truck's drain plug exactly.
Post: # 3200Post TC Chris »
The Fatsco guy e-mailed back that if its a cast-iron Powerglide, their device fits it.
And I have an appointment next Tuesday with the shop next door to my office for the Ford drain plug. They're the lace with the '65 Mustang and the Isetta on the premises at the same time. I bought two new drain plugs. The parts shop and them in 13 mm and 16 mm. I'll favor the bigger one unless there's some reason not to.
Post: # 3464Post TC Chris »
The Chevy went into a winter storage place today--the cleanest storage building you'll ever see. Then tonight we are going through my mother's cancelled checks from the '60s. Yup, you read the right. Lots of receipts too. And here's the exciting part. I found the window sticker for the Chevy, the original 1961 window sticker. Yay!!!! It pays to sort through the documents.
Post: # 3467Post electra225 »
What was the sticker price on your Chevy?
Post: # 3468Post walyfd »
That's a treasure! What's the dealer name and code, if it's on there. We've been trying to cross-reference dealer codes to dealer names since you can get Cadillac build sheets from GM Historical. All they show is an "outlet code" so I THINK my '62 came from Simon's in Cincinnati.
What I wonder is was that code GM uniform if it was a Chevy cadillac dealer or was it based on the division...
Post: # 3471Post hermitcrab »
19&41 wrote: ↑Tue Nov 23, 2021 12:25 am I have 3 sets of metric sockets and only one in the 3 sets fits my truck's drain plug exactly.
My son drives a little 2012 chevy sonic ... he went to change the oil and used the correct 14mm to remove it ... it was on so tight he twisted the head of the aluminum nut off leaving the stud in the pan ... of course the chevy dealer sells him a new oil pan.. which with labor was like 450 bucks installed.... problem is they put the same crappy set up that was in there so it will just occur again in a few years... the new stuff is junk...
Post: # 3476Post Firedome »
Aluminum Slaloominum... iron and steel are what proper cars are made of, engines are meant to be made of iron. My wife once drove our '73 Olds 350 with a Red warning light on for 20 miles on the Vermont I-89 Interstate hoping to get to the next exit. When she pulled off the ramp and stopped the local small town cop stopped and popped the hood. The lower hose had broken 25-30 some miles back, no water in the rad, (and turned out 1 head gasket was damaged from the overheating) The exhaust manifolds were glowing bright red, so hot that the spark plug ends had melted! Towed it home, pulled the heads for 2 new gaskets, replaced the hoses and fluids, and that awesome Rocket ran like new for 2 more years until it was sold for a 38k mile '78 LeSabre 350. Try that with an aluminum block and head engine!
Post: # 3528Post TC Chris »
electra225 wrote: ↑Sun Dec 05, 2021 4:32 am What was the sticker price on your Chevy?
$3535.35. Not kidding. Maybe the printer got stuck.
Post: # 3529Post TC Chris »
walyfd wrote: ↑Sun Dec 05, 2021 11:44 am That's a treasure! What's the dealer name and code, if it's on there. We've been trying to cross-reference dealer codes to dealer names since you can get Cadillac build sheets from GM Historical. All they show is an "outlet code" so I THINK my '62 came from Simon's in Cincinnati.
I knew the dealer because I have the hand-written invoice. This is just icing on the cake. It was Hugh Hanson Chevrolet-Cadillac in Standish, MI. Above "dealer to whom delivered" there are these numbers: 257 099. And then in front of the dealer name there is this: 1-260. I knew it was built in Flint from an online database using the VIN but this confirms it.
Post: # 3531Post walyfd »
Thanks for posting the numbers. I have some internal directories from Cadillac's Clark Ave hq. Hopefully numbers will match.
Post: # 3537Post William »
257099 is the GM parts reference number. The dealership was assigned a number by GM parts. The dealer I work for had two parts dealer codes. The main one was 250152 which covered the parts department at the dealership. The other code was for the wholesale parts warehouse. That number also told the delivery driver where to drop off the parts.
