This forum needs to share a project....
Concert Grand or Pioneer SX-1050
Poll ended at Wed Mar 05, 2025 5:54 pm
1. Pioneer SX-1050
1
25%
2. Concert Grand
3
75%
3. Something else
0
No votes
4. None of the above
0
No votes
Total votes: 4
Post: # 25197Post electra225 »
So I reckon I'll volunteer. I have two projects I am considering. Going thru my old Pioneer SX-1050 receiver and the other is a component-by-component overhaul of the Concert Grand, much the same as I did to the Imperial last year. If I do the SX-1050, I will need coaching by those on here who are more familiar with solid state stuff than I am. The Concert Grand has a stuck phono motor and a chunk of something that is shorting out the FM tuner mid-dial. There is a short in the AM external antenna connections someplace. I'd like this project to be like the ones we used to do on the old Vintage forum. Where we all put our two cents in and learn something together. What say ye? Which one would you prefer? Should we do a poll?
Re: This forum needs to share a project....
Post: # 25199Post TC Chris »
Both projects are of interest. I've got a few old Pioneers around.
Post: # 25200Post William »
Since I am completely ignorant when it comes to solid state I would vote for the CG. I know SS is kind of like tube stuff, it is all of the little components sitting crowded on top of the PC boards that scare me. That is my 2 cents.
Post: # 25205Post electra225 »
The Pioneer is the one I'd really like to start with. There is nothing in that thing that looks familiar to me, so that is a bit scary. In fairness, the first time I saw the bottom of a TV chassis, I wondered how in the world would you ever fix one of those things. I'll probably just need to order a five-gallon bucket full of electrolytic capacitors and get to work. The SX-1050 has a wonky left channel. It works, then it starts squealing, then it farts, then it blows a speaker, then it is silent until the next time it decides to work. I do think the problem is after the shorting clips where you connect an equalizer. I think the front end of the receiver is okay. The problem is likely in the output section or maybe the audio section. I need to see if a schematic exists for it, then figure out a plan to troubleshoot it. The thing is worth a small fortune if it works. It will be for sale when I get it done. I'll never use it again....
I'll probably need coaching to troubleshoot it. :oops: ;) :cry:
I plugged in my Coke radio this afternoon. The fire flew from the power strip, which is now fried. Apparently, the power cord on the Coke radio had gotten bad since I used it last. So, I got to remove the chassis and replaced the power cord. This Coke radio is the 1949 model with the Majestic 5A410 chassis. I have the Majestic radio with that same chassis as well as the Stark model 1020 knockoff. My Coke radio has the 12AT6 first audio tube. The Coke radios could have a 12SQ7, 12AT6 or a 12AV6 detector-first audio tube, depending on when it was built. Ken-Rad tubes appear to have been original in my radio.
danrclem
Post: # 25216Post danrclem »
My vote would go for the SX-1050. I guess it's because I have one too. Mine doesn't work at all and I'm guessing that it has blown output transistors. I probably couldn't add anything of value to the project but maybe I could learn a few things. I can change parts but when it comes to diagnosing a problem, I'm almost clueless. Unless it's something really obvious.
Post: # 25217Post electra225 »
I've been watching videos on the repair of the SX-1050. Nobody addresses the issue I am having. Not knowing squat about solid state devices, I am of the belief that the problem with mine is a capacitor. I'd think if it was a transistor, it wouldn't "fix" itself occasionally. Every video I have ever seen is more concerned with what can go wrong with the repair, rather than giving useful information on how to troubleshoot. The problem with the SX-1050 is that it is fairly complex and has boards and parts that don't have anything on them that makes any sense to me. The first thing I need to do is to find a schematic for it, if one exists. You might be more help than you realize, Danny. If you have one, perhaps we could go thru both yours and mine at the same time.
Post: # 25218Post TC Chris »
I've got a Sams book that includes service info for the SX-1000. If you can send the circuit board numbers, I could check to see if they re-used any of the components. I have seen duplication or re-use before.
Post: # 25220Post electra225 »
Thanks, Chris. The SX-1000 models are totally different from the SX-1050. My Google searching ability is legendarily horrible, incompetent. I find things I need when I'm looking for something else, typically. I was looking at the SX-1000 when I came across this. I think the downloads are free. There sure is a lot to an SX-1050, lots of parts. I might be able to print out what I need as I need it.
https://www.manualslib.com/manual/90251 ... -1050.html
Doug
Post: # 25225Post Doug »
Think u can isolate your issue with freeze mist and hair dryer.
Your issue starts after warm up after turning it on so slightly heat a small area at a time till it starts acting up then lightly spray each transistor till it stops. If u can reduce the area of of the heat area would help.my heat gun has different size nozzles
Protect your Speaker during test by putting a non polarized cap in series maybe 50vdc np 100 or more uf.
Or use a 10watt or higher wattage resistor 20 ohms or more in series with the speaker and a 8 ohm non inductive across the Speaker.
Or fuse in series maybe
Or if you can here it in the headphones just leave Speaker off.
Post: # 25230Post Hi-Fi-Mogul »
I found the manuals library site, also.
Looks like good info there, and organized.
Also, a source at hifi engine, which may be the same
svc manual as in manuals library.
https://www.hifiengine.com/manual_libra ... 1050.shtml
And here:
https://archive.org/details/manual_SX10 ... 9/mode/2up
danrclem
Post: # 25231Post danrclem »
It sounds like Doug has a good way of checking things out. I had read of using a freeze spray to make things compress and work but the hair dryer is new to me but it really makes sense.
I have an SX-750 that completely quits working when it heats up so maybe the hair dryer trick would work on it. It sure would be cheaper than buying freeze spray. I can smell a heat when it stops working. I have an infrared thermometer that I've been meaning to use on it.
Greg, it sounds like we have two completely different problems so if I throw mine in the thread, I may be making the water muddy for you. If I have any ideas, I will let you know what they are.
Post: # 25236Post electra225 »
Danny, you can start your own topic and the two could run at the same time. That will save confusion, if that is a concern. Just an idea..... ;)
Thank you Doug for your input. I am learning, this would be my first solid state project ever. If I ask a question, please understand that I don't intend my question or comment to be contrarying anybody. There is a lot I have to learn and have a zillion questions and I appreciate everybody's input.
The voting, if anybody is interested, has the Concert Grand project winning so far. ;) ;)
If we continue with this project, I have a couple of old speakers I don't care about that I can use. They are old 6X9 car speakers than can take a million watts or some such nonsense. If I "take them out", I have some Radio Shack speakers I can replace them with, so that isn't an issue. Next, you are saying to fire up the amp, then use a hair dryer or heat gun to put heat on the transistors, (output transistors?) then see if they act up. There are "rebuild" kits available for an SX-1050 that gives all the caps needed and the output transistors. Is such a kit worth considering? It's been while since I used this receiver, but, if memory serves, it will run for hours just fine. You can turn it on a dozen times with no issue. Then, when you least expect it, it messes up. Again, from memory, I think it squeals, then it farts (heavy-duty motorboating) then the left channel quits. And, again, if I understand Doug right, he suspects transistors. When it farts, your speakers are done, history. This thing has always been hard on tweeters. I read somewhere that this is a feature of that amp if "something" is happening, I just can't remember what they said the cause was. The only set of speakers that took what this amp would deliver was a set of ugly Peavey studio speakers with an 18" woofer, 12" driver and a big horn in each speaker. They were uber heavy and were on casters. The wife thought they were ugly and that I played them too loud. They did produce bass that would give you a concussion.....I rue the day I sold them. :oops: :oops:
Post: # 25237Post TC Chris »
Squeals and motorboating oscillation sound like an electronics component issue, but the fact that it happens sporadically makes me wonder if maybe it's in the protection circuit. Some solid-state devices have turn-on delays to avoid speaker thump.
I have a Denon amp in my living room system and periodically the R channel doesn't come on. I'm pretty sure it's an issue of the protection-circuit relay having dirty contacts for that channel. If I crank up the volume it might come on, but turning off and on again is working better.The amp in service before that was a Sansui AA-717 that developed a turn-on problem also. Online sources talk about its complex protection circuit. I have not got around to diagnosing it.
Post: # 25239Post hermitcrab »
some of these late 90's early 2000's solid state units fail just by moving the unit from one place to another .... I had two units that failed just by picking them up and moving them... it's called silver solder ... it's junk... I have fixed dead units by reflowing the solder... no different from the expensive PlayStations that quit after a year... the solder fails... the late 70's and 80's should still use old fashioned rosin core solder ...
danrclem
Post: # 25240Post danrclem »
I have read on AK (haven't been on there for a long time) that the Ebay rebuild kits will probably user cheaper parts and may not be complete. All kits may not be equal though. I have also saw where BOMs (think that means Bill Of Materials) have been posted making it easier for finding all the parts you need. I would think it's very possible that a SX-1050 BOM could be there.
Post: # 25264Post electra225 »
Thank you all for your input on this topic. The votes are three to one for the Concert Grand. So, accordingly, I reckon the CG will be "it". I'll do some moving and stacking so I have LOTS of room, and get to it. I'll keep this topic for reference when it comes time for the SX-1050 to be on the bench. I'll start a topic on the Concert Grand on the Magnavox board. You guys feel free to jump in and add your two cents. Obviously, bass response will be a major concern, so, if you have input on that, feel free to jump right on in....... ;) ;)
Post: # 25271Post William »
If the schematic for the CG is not in the downloads please provide it so everyone can follow along. This should be fun, and thinking back to when you recently overhauled your Imperial and the difference that made this could be an exciting out come. After all, your wife always referred to both the Concert Grand and the Imperial as over grown clock radios with the way they sounded. Now the Imperial sounds like it should have when new and hopefully the CG will as well once you are done.
Doug
Post: # 25274Post Doug »
It's a stereo. Maybe the speakers are not wired correctly.
Does it have more bass when only playing the left or right side?
Have a good evening
Doug
Post: # 25275Post electra225 »
No, it has Magnavox bi-amps. Known for wimpy bass. Maybe we can find an answer and improve matters in that regard. My intention is to do a component-by-component restoration like I did on the Imperial, the little sister to the Concert Grand.
Doug
Post: # 25276Post Doug »
Please post a model number.
Does sams have schematic for it?
Do u think the woofer may limit the bass response?
Have a good evening
Doug
