Fixing a wind chime
Fixing a wind chime
Post: # 2546Post electra225 »
One of the wife's wind chimes has fallen apart. The string got rotten. She thinks I can fix it. Looks like a Rubic's cube to me. This is one of those deals a guy gets himself into, then can't bail himself out of. Any suggestions by those wiser than I? ;) :oops:
Re: Fixing a wind chime
Post: # 2548Post 19&41 »
I make wind chimes. Measure the length after tying off the smaller pieces then get a sharpie and mark your line where you want the knot to get neat results.
Post: # 2549Post electra225 »
I thought about using small sinkers to give me something to secure the line to after I make a knot. I also considered using Elmer's construction glue to make sure the knots stay tied. This particular chime is not very well made. I can see a couple mods I can make that will make it more sturdy. Am I all wet on this?
Post: # 2554Post 19&41 »
Tie a couple of simple knots. then draw the line tight, then pull the line that will hang the item, so it draws completely tight with no pull through. Use your marked line with just a couple of knots with no drawing it tight, just the tight knots, so they will stay in position. leave about a 1/2inch of free line off the knot. If it's holding a heavy portion, loop the line through twice, then knot it. I use mono fishing line for mine. It lasts about 3-4 years before it oxidizes and goes brittle.
Post: # 2555Post electra225 »
Thanks, Rex. Do you hang them up, or work on them on a bench?
Post: # 2560Post 19&41 »
I make most of mine with the aluminum rod they sell with the metals they sell at home depot. I cut them to varying lengths and they chime nicely, I drill a hole at the top to run the line through and tie them and pull the double knots for a straight hang, with the line cut to a length to allow tying to the body. You mark the free end to tie to the body at a specific length with one or two tight knots with 1/2 inch of the line off the knot. I either hang the chime pieces in close proximity to strike each other, or have a striker with a little sail to strike each. The aluminum makes a beautiful sound, and can be sized to make musical tones. I tie the chime pieces in a panavise, then put the body in the panavise to tie them to it.
Post: # 2565Post electra225 »
I like wind chimes. They sound soothing, homey. The wife has six of them hanging out on the patio. They are chiming now as I type this.
Apparently, my maiden voyage into chime repair has been successful. I got some cord at Walmart called "braiding cord". It seems to be easy to work with and looks like the original cord. I triple-knotted the cord where it went into the doodad that held the chimes. I made the length from the thing that holds the chimes to the hook about eight inches. I made the first dinger 16" from the hook, then the "flag" that makes the dinger bang into the chimes 32" from the hook. I used Elmer's Construction Glue on the knots, since I was not confident in my tying ability. That should keep them from coming apart. I might try to make a chime from scratch one of these days. Working with chimes is a rather relaxing activity.
Post: # 2568Post 19&41 »
So is listening to them.
Post: # 2570Post William »
Rex, do you have any photos of the ones you make? If so, would you share please?
Post: # 2572Post 19&41 »
They're not too fancy, but I'll try to put a couple up.
Post: # 2573Post electra225 »
I'm thinking about making one with large tubes, kind of a bass chime. Wonder if that would be possible/practical?
Rex, I'd like to see some of your chimes. I can see how you'd enjoy working with them.
Post: # 2574Post William »
Thanks, Rex.
Post: # 2578Post 19&41 »
I made one from an apple shaped spun brass vase. I cut separators on the striking surface so it would give different tones when the ring shaped striker would hit each area. Brass and bronze make much better sound than copper.
Post: # 2583Post William »
Rex, do you keep them all, or just hang them around your house?
Post: # 2590Post 19&41 »
I've given a few as gifts and have made a couple from objects folks wanted to try. Thrift stores are fertile ground for materials. one I gave as a gift was one made from a brass howitzer shell. That would only do one note but it was a deep and longer duration tone.
Post: # 2592Post electra225 »
I reckon the different parts of a wind chime have proper names. The hexagon wood part that holds the strings is called what? The dinger probably has a correct name. The chimes are the metal parts that make sound. Then there is the piece on the bottom of the center string that catches the wind to make the dinger contact the chimes. I hadn't given the mechanics of a wind chime much thought until this one broke. I must be easily entertained. I also may have a new hobby. I'd like to get more into wind chimes.
Post: # 2595Post 19&41 »
I compare them to parts of a bell. the structure that supports it is the yoke. The dinger is the clapper. The difference starts when there is no clapper used to strike what I call the sounders, when their striking each other makes the sound. I didn't get a chance to take a pic of mine, as I was trying to get the truck ready to drive to work. I use different materials and items to act as sounders. I have one I made in 1997 from 2 short brass square tubes suspended on a copper chain I made, soldering each link. I used copper wire to make bales to suspend the tubes and brass shim stock as the sails. That is what I call them as they catch the wind to clap the clapper.
Post: # 2596Post electra225 »
Thanks, Rex. What criteria do you use when you select sounders? How do you choose materials for sounders? Then how would one choose a clapper appropriate for the sounders? Does the length of the string used to suspend the sounders make any difference in how they sound?
Post: # 2597Post 19&41 »
If you are looking for something like a vessel or vase, take awl or a similar pointed tool and invert the prospect and hold it up with the awl, mouth down, and ring it. With flick of the finger, or metal to metal, a key or a ring It will tell you if it has potential. Some items are a leap of faith. The aluminum rod I use as it comes has as much tonal property as a piece of lead flashing. Cut them in shorter lengths, up to 3 ft. they ring like the bells of St. Mary's. You have to experiment with hanging them, Thicker cord, as opposed to monofilament fishing line can dull a sounder. If you are going to use tubing as you mentioned, you should get a tubing cutter and be prepared to trim off the remnants of the cut to have just the wall of the tubing at each end. You need to get a length, put it on a line, then trim, strike, listen for the tone you want, cut and try again. as to getting a proper clapper and sail combination, you need to experiment with a fan and set up the combination you think might be right and let it do it's stuff. A short tail with the sail off the clapper might work best for a longer throw. a longer tail and sail will strike less frequently. It's trial and error. a goodly spool of 25ib. test mono should be pretty cheap at WalMart. Big hint. Keep track of all pieces and clippings of the line. Vcuums have issues with them. I use fluorescent line. you can see it to tie it and clean it up.
Post: # 2598Post electra225 »
Thanks, Rex. I noticed that all my wife's chimes have six sounders. Is this common, or do some have more or less sounders? I read where you made a chime with two sounders. This may be something I can experiment with.
