looking for model identification
Kathleenc
New Member
Post: # 24396Post Kathleenc »
Hi from Grapevine, Texas. I recently recovered a 2-part Magnavox console and had it refurbished at Dallas Vintage Audio. It sounds fabulous but the lid stay does not keep the lid open. Was hoping to find out year it was made and model information so I can search for a replacement. In the meantime I have a stick (ha ha) propping it open when I play my vinyl. I welcome suggestions!
Re: looking for model identification
Post: # 24397Post electra225 »
Welcome to the forum! We are thrilled that you joined us. We have a lot of friendly folks on here who are always eager to help. :D
You told us you were from Grapevine, TX, which is why I approved your first post. Please refer to the message board at the top of the index page, under the header. Please include your location in your user profile.
As to your question, we will need more information. Pictures will certainly help. Some of the older Magnavox stereos used a friction type of mechanism to hold the lid up that has proven to be cranky in their old age. I am not aware of new replacements being available. Sometimes they can be adjusted thru a hole in the back of the cabinet, sometimes not. Sometimes, you can remove the mechanism and repair it. It varies on a case by case basis. Perhaps some of the other members may have ideas as well. I have a friction mechanism in my Imperial stereo and I use a paint stick to hold the lid up. Mine is not repairable.
Post: # 24399Post William »
Welcome, and yes to everything Electra 225 said. I too have an Imperial and need to use a paint stick to hold my lid up. There is a spring thing in the support mechanism that has an adjusting screw in the back of our Imperials. When I tried adjusting mine the spring broke. If you follow Electra 225's instructions you will then be able to provide us with some photos which will help us to identify your Magnavox. Again, welcome, we are glad you found us.
Post: # 24402Post William »
First, thank you for completing the required steps to become a member and thank you for providing your Avatar, now we know which Magnavox you have.
And that Magnavox is called the Modern Concerto. If it is phono only, it is model number 1-SP280F. If yours has the tuner it is model 1-SP281F. A few more posts from you and you will be able to view the "Downloads" where you will find the "Brochures and Catalog" section and in there you will find lots of Magnavox brochures and catalogs that will show you the different models including yours.
Again, thanks for completing the required steps and please take the time to really look over the forum, there is a lot of excellent information to be had.
Post: # 24406Post electra225 »
What Bill said..... :D :D
Thank you for your cooperation and welcome aboard.... :D :D
Post: # 24414Post TC Chris »
It is always nice to find original parts, but if you cannot, woodworkers' supply places offer a variety of lid supports.
For example, go here and search on "lid support" and you'll see several types:
https://www.woodcraft.com/search?q=lid+ ... w=products
Or here:
https://www.rockler.com/search/lid%20support
If neither of those has what you want, do a search on "woodworkers' supplies" and try some of the others. Or try McMaster-Carr.
