Soldering 2 wires together !!!!
Post: # 24339Post Hydrolastic »
Hello Guys, Today I broke out my grandfathers soldering iron ( big Weller gun with he 2 prong tip) and was installing a power cord onto the power supply of the CG. I had to solder two wires end to end. First I tinned both wires. then I tried to hold them together and with the iron and solder together but the solder would melt and the wires would separate and I would have to start over again. Is there a tool or technique that I need to use or do to do this properly ? Thanks in advance. Hydro
Re: Soldering 2 wires together !!!!
Post: # 24342Post TC Chris »
It's always best to secure wires together so you have a solid mechanical connection before soldering. Secure first then do the soldering for electrical connection.
Post: # 24343Post William »
I use one of these when I need extra hands. It works great for soldering wires together or the little connectors that go on the fine wires for cartridges.
https://www.harborfreight.com/helping-hands-60501.html
Post: # 24348Post electra225 »
I was taught to solder two wire ends together you would first separate the strands, then mash the two ends together, wrap the strands around each other for a tight mechanical bond, then solder. Don't forget to put some shrink tubing on one of the wires before you solder.
Post: # 24363Post Hydrolastic »
Hello guys. so in my defense its been forever since I soldered something, Here were the issues. I ended up taking a file to the tip and then I went and got the rest of the supplies and put the tip in the flux while it was hot and then put a nice smooth coating of solder onto the tip. I guess it's called being " tinned". I then soldered the wires by twisting them together then soldering them together the soldering iron tip was much more effective without the cruddy layer on it.
Post: # 24367Post William »
It is important to keep you tip clean, it makes for better heat transfer.
MEZLAW
Post: # 28863Post MEZLAW »
electra225 wrote: ↑Sat Jan 04, 2025 3:48 pm I was taught to solder two wire ends together you would first separate the strands, then mash the two ends together, wrap the strands around each other for a tight mechanical bond, then solder. Don't forget to put some shrink tubing on one of the wires before you solder.
I agree with Greg, this is the same way I make my connections.
Post: # 28864Post electra225 »
In my old age, I find I get along better with my soldering if I dip the hot tip of the soldering iron in rosin flux first. I'd never done that until just recently. I saw the idea on a video I watched. I also like to cut the lead of a cap when I replace it, "J" hook the end, and make my connection like that. Nice, solid mechanical connection and I don't take the chance of messing up a tube socket or other unobtanium component.
