RCA orthophonic console remote speaker
Post: # 23309Post hermitcrab »
does anyone have the specs on one of these from the 50"s ? didn't some have their own amplifiers built in ? I got that wood sitting in my garage ... just sayin....
Re: RCA orthophonic console remote speaker
Post: # 23317Post William »
Elton, do you have a photo of what you are looking for?
Post: # 23332Post hermitcrab »
Just wondered what the remote speaker looked like for the SHC-8
Post: # 23344Post William »
Elton, it looks like the main cabinet only half the size. I have a photo of mine that I can share if I can find it.
Post: # 23352Post William »
Elton, I was gone this past weekend, so I had to wait unit I got home and, on the computer, to provide you with this photo.
Post: # 23354Post hermitcrab »
what does it have in it?. just a speaker?
Post: # 23359Post William »
One 12" RCA type speaker and two RCA type tweeters.
Like this but with just one woofer. I am guessing your main unit looks very similar to mine which is the photo attached.
Post: # 23364Post hermitcrab »
William wrote: Sun Oct 27, 2024 12:24 pm Elton, it looks like the main cabinet only half the size. I have a photo of mine that I can share if I can find it.
Bill {quote]
So would it be safe to say , just cut in half the measurements of the main unit for the satellite speaker?
Post: # 23382Post William »
Elton, the aux speaker is probably bigger than half that of the main unit. If you would like, the next time I am at where it is stored, I could take some measurements.
Post: # 23392Post hermitcrab »
That would be awesome , it is definitely something I think could be easily built.... :)
Post: # 23397Post William »
Next time I'm out there I will get that info for you.
