Tinkering with OTA TV broadcasts
I bought a "50 mile" RCA antenna to use with my old TV sets. My results have been semi-successful. I can't get Channel 12 the NBC affiliate. And, worse yet, I can't get MeTV on antenna. I thought that was "AZ 7" but I can't even get it on the channel list. I have a friend who has no cable, uses OTA only, and says MeTV is not available over the air, so there is that. Performance is good, for the most part. The only set I have tried this on is the old Silvertone console. I get some buzz with the digital converter box that I don't get with the DVD player. Both the converter, the TV and the extension cord I'm using have polarized plugs, so reversing the plugs to eliminate hum won't work. The antenna I bought was less than $20, so maybe being cheap is not going to work. I may need to spring for a better antenna. Most of the TV stations I can get are broadcast off South Mountain, about 35 miles as the crows fly. Channel 12 is broadcast out of downtown Phoenix, so I may not have enough antenna for that. The old Silvertone set has a beautiful picture.
Re: Tinkering with OTA TV broadcasts
It sounds like you have success, just not all the channels you want. If MeTV is not available OTA, then I would call it good enough and be happy with what you are getting. I have an OTA antenna that is a good one, had it for years, and in the GR area it worked great. Now living in the pucker brush, I only get 6 channels. Having said that, those 6 channels were before I raised the antenna above the roof line. I have not tried it since.
2nd try; my post just disappeared.
Some years ago the tenants at the little cottage I used to rent out in the summer asked for a TV to see the news. I bought a small flat screen ("Polaroid" brand!!) and got out an old 3-bow-tie UHF antenna. All OTA transmission is UHF now. I pointed it in the direction the neighbor's big tower-mounted antenna was pointing. It uses twinlead so I added a balun at the TV end. That pulls in 12-15 stations. The public station and at least 2 commercial broadcasters have several channels each
Who knows what might be available if there were an antenna rotator. And I bought an amplified UHF antenna as well but have not installed or tried it. The part of Michigan where the TV lives has little topography so the mostly line-of-sight UHF propagation is not as much a problem as it would be in a hilly area or one with lots of tall buildings. Even so, height matters, which is why my old neighbor had his tower, rotator, and big antenna.
- Conelrad
MeTV comes out of Prescott via KAZT, your SMTN antenna is on a different azimuth.
All high-power TV stations in Phoenix broadcast from SMTN, including CH. 12.
However, as ATSC-3 comes to be law, it will be necessary to rescan as some channels have moved around the dial, frequency-wise.
Also, it is difficult to properly aim a TV antenna nowadays, as enough data bits have to be counted in the TV before any image will show and that trial & error can take a lot of time without a real-time RF level meter.
Supposedly a current chart of OTA TV in the metro: https://www.tvchannellists.com/w/List_o ... in_Phoenix
D
D
Do I need a better antenna? I remember the good old days when you could get three channels by rotating the antenna with a pair of Vise Grips,,,,
I thought Channel 12 was the only Phoenix TV station NOT broadcast from South Mountain. I thought their transmitter was down by the Suns stadium....
- Conelrad
On my next visit there, I'll bring my spectrum analyzer and we can aim what you have on the best signal.
I'm 40 miles from SMTN, and can RX almost 90 channels, counting all the subchannels.
Just curious, what made you think Ch 12 was downtown?
D
D
Who knows? Just what I THOUGHT I remembered. You are the broadcasting guru, so I was obviously mistaken. Odd that I get all the other "majors" except Channel 12 if they are all broadcast from South Mountain. 3, 5, 8, 10, 15, 45, but not 12. I can't get 7 or 51, either, but I don't call them a major station. It's been a long time since I messed with a TV antenna, and never during the digital age. I could use your help, obviously.
I've built a number of these. They work great for next to nothing!
I've got one in my attic that feeds a splitter/amp in the basement and runs to the various rooms in the house.
I think I ruined a former coworkers day when I told him about mine after he spent $80 on a store bought antenna.
There are a number of videos on the subject, but this was the original that inspired me to try it. I've done some mod's like threaded bolts, nuts and washers to hold 12 ga. copper wire instead of coat hanger wire, just to get all fancy.
Go ahead....try it...you may be surprised...
https://youtu.be/EWQhlmJTMzw?si=gTThefmYaRcAkPMB
Thanks for all the info, guys. All of the homemade and store-bought OTA antennas seem to work well when you live in the city but here in country bumkin land not so much. I have a good store-bought antenna and even though it does work reception is sketchy and the number of channels I can get is limited. Any suggestions for my situation?
- Conelrad
All the outdoor antennas are directional, to get the necessary gain to overcome distances from transmitters.
The problem arises when your locality is served by several different stations, at different locations.
Your choices are to put your antennas on a rotator so you can select the correct azimuth, or multiple antennas switched to select the station you want to watch.
Digital TV is messy compared to the old days of powerful analog transmission systems.
Bill, I'd try building the one shown in the video. Insulate there the conductors cross over. Pay attention to lead dress (try to get the cable at right angles to the plane of the antenna and to direction.
I built a Yagi FM antenna after a move, when I could not receive my public radio station reliably on an omni. It was night and day.
I'd be inclined to try the free DIY version first. And I would probably do it with copper wire.
