Expensive mistake but who's at fault?
Post: # 22752Post hermitcrab »
My wife called me saying that her and my grandson were stranded on side of the road , said the car sputtered and died and would not re-start , she just left a gas station ... she filled it full of diesel... I was incredulous that she was able to get the diesel nozzle into a gas tank .... turns out this particular station which we never go to , uses the same size nozzles for everything... my wife being distracted by my grandson picked up the diesel nozzle instead of the gas nozzle ....I thought the FTC was supposed to regulate this type of stuff ....a diesel nozzle should not fit in a regular gas tank... my friends told me to get a lawyer and fight for some of the damage costs ... I think a lawyer would cost more than the cost of fixing the car ... but it is BS this can happen
Re: Expensive mistake but who's at fault?
Post: # 22753Post electra225 »
They may have some liability, but, like you said, it would cost more to litigate the matter than it would to just fix your car. I don't know what kind of car you have, but when I was wrenching, this kind of thing happened frequently. Most times, we would drain the fuel tank, put in fresh gas and the car would take right off. I don't know what would happen to modern cars, though. My Mini won't run on regular gas, you need premium. The computer shuts the fuel off after the little English gal comes on the radio speaker and yells at me for putting in the wrong gas. Most diesels will run with gasoline in the tank. They get horrible mileage, since there isn't as much energy in a gallon of gas as there is in a gallon of diesel fuel. I hope this incident will be easily remedied....
Post: # 22757Post William »
Ouch, I wish you the best, Elton, and I hope this mistake is not costly. I hate it when they sell diesel and gas at the same pump.
Post: # 22761Post hermitcrab »
well, $650.00 lighter , they drained the tank, blew out the lines , removed and cleaned the injectors , changed the oil in case of contamination ... but oddly enough the car seems to run better , guess the injector cleaning helped ... I would have rather bought a can of injector cleaner and did it that way...
Post: # 22765Post William »
It sounds like they did everything right, and if it runs better, I guess it was worth the money, but it still hurts.
