Fluke meter
- Hydrolastic
Fluke meter
Hello Guys, Ok so I have the fluke meter I got it off of eBay so no manual with it. It has icons instead of words (I hate that). My Continental the woofer in channel 2 is not working. I want to measure the speaker outputs H C L, What icon do I use. ? Thanks in advance
- IMG_1682.JPG (83.78 KiB) Viewed 30784 times
Re: Fluke meter
Hydro, here's the manual I pulled from the internet, I hope this helps to answer your question.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.myflukestore.com/pdfs/cache ... manual.pdf
Re: Fluke meter
not sure what HCL is ? but while it is playing you should have varying AC signal at the speaker terminals ....flukes are nice meters .
