Wanted: Badge for Magnavox Continental
Forum rules
Post: # 63Post Hydrolastic »
Hello People, My Magnavox continental is missing the badge that is in the record compartment. It's the bright brass colored one circled in the photo. Photo is not mine. Pm me
Continental badge .jpg (30.35 KiB) Viewed 32978 times
Re: Wanted: Badge for Magnavox Continental
Post: # 2386Post Hydrolastic »
Hello, Found two now and i will be polishing one to a bright finish with a lacquer seal coat afterwards. Thank you, Hydro
Post: # 2399Post electra225 »
Thanks for the update, Hydro! Did you find them on ebay?
treavahattan
New Member
Post: # 22881Post treavahattan »
Hi,
Are you still searching for Badge for Magnavox Continental?
I am reaching out to you because I know a trustworthy guy you will appreciate, Kenneth, might still have kenneth.thurmond@proton.me
Post: # 22954Post hermitcrab »
the small ones on the changers and radio bezels are always missing , glue long since dried out
