What is your go to?
Discuss music and media, records, tape, CD's, reel-to-reel, cassettes, whatever. Artists and genre discussions.
What is your go to?
Post: # 2159Post hermitcrab »
Ok... you just finished that project... be it a console or component piece, time to try it out.... what is your go to music and source to test your work?
personally I play Nilsson / Jump into the Fire, on vinyl .... the drums and deep bass give it a workout ...
Re: What is your go to?
Post: # 2162Post William »
With me, it depends on what I just finished. I have a couple records that I use. One is Jazz, one vocal, one Classical, one Big Band, and one Theater Pipe Organ. Each one has it's one characteristics that will really give you what the restored unit will do.
Post: # 2194Post electra225 »
I made a series of CD's I entitle "Magnavox for 19XX" I have a CD for 1959 thru 1963. I have a later one in production. I take the music of those specific years and play them on instruments of the same vintage. I try to figure out what the engineers of both music and reproduction equipment had in mind when their products went into consumer use. I choose passages that bring out certain characteristics in a Magnavox. The demonstration records made for Magnavox were great, but not something you would listen to on a regular basis. They were made to sell instruments. This is the music people would have listened to back when they were new.
Post: # 2217Post Firedome »
When H. H. Scott (Herman Hosmer) went to audition a new product, he, with selected seasoned musicians, would listen to the new product blind with the same passages of music alternating between the new product with that being played live by members of the Boston Symphony from behind a curtain, a pretty tough standard. Reel to reel 35mm tape, and for speakers, I'd like very much to know what were used in those sessions..
I've always found complex symphonic with choral music to be by far the most difficult to reproduce clearly without congestion or "muddiness", a 108 player symphony and a chorus of 100s, ala Beethoven's 9th "Chorale", or the ultimate, Mahler #8 "Symphony of a Thousand" ala the 200 instrumentalist and 800 chorus performance for Quebec's 400th birthday in 2008. Just incredibly demanding of a sound system and will quickly bring out any weakness at higher SPLs no matter how good it may be! Doing this can lead to some very expensive dissatisfaction, sort of like drinking a fine 1982 Cos D'Estournel St. Estephe Bordeaux then having to go back to Franzia. Sometimes it's better not to enter the slippery slope of perfectionism.
I also like jazz solo voice and guitar for high end definition. But I don't do any of this kind of critical listening as much as 30 years ago, nowadays it's mostly casual background listening while doing other stuff, and for that modest priced consoles and radios are just fine.
Post: # 2332Post Motorola minion »
Many records were handed down from parents and grandparents on both sides, being that I'm the only willing custodian of them. I have found many records are mono only, though assumed purchased in the 60s after stereo was a standard.
I attribute this to the fact that many mono players were still in service and a stereo record would simply not be compatible, wearing quickly because the mono cartridge has no horizontal compliance. Still, they are "HiFi", likely meaning RIAA equalization was used to record them. I have a test record by CBS "seven steps to better listening" that I use only after the player is put back in the console and playing through restored electronics.
Anything with horns and drums seems to confirm quality reproduction to my ears, so I have Tito Puente, Billy Vaughn, Herb Alpert and Al Hirt LPs ready for that first play. Not in the best condition from handling and being in the shop, these discs confirm speed and tracking to my jaded ears.
I will then confirm speed with a strobe disc, tracking force with a small balance/weight set in 1 gram increments. There is nothing like and upbeat classic record to assess how a player will respond to the more "popular" LPs the customer might play. Al Hirt puts a "hurt" on lousy tweeters or crossovers, which is obvious even to my worn-down ears.
Post: # 2335Post Firedome »
Ah, "Java"! Our next-door neighbor, an engineer at Westinghouse, used to blast that at top volume on his home-built Heathkit tube system with huge horn speakers, and I can't hear that song without thinking of Mr. Kenney. No doubt trumpet and acoustic guitar are a great test of system quality for general listening, and a good condition Enoch Light "Command" record is also a great test subject.
I still have some Herb Alpert records bought in the '60s but they are so worn out they wouldn't be a good test of anything!
Post: # 2344Post hermitcrab »
Another good record especially for testing a 3 channel like a motorola is Enoch Light's Dimension "3"
Post: # 2352Post electra225 »
I have an Enoch Light Command record that is demonstration record for Concert Grand. I will go to my grave believing that side one is Lawrence Welk. I've been told I'm all wet. IF it is not LW, then Enoch Light was able to mimic him note for note. Not an easy task, given Mr. Welk's proclivity to improvise his sound. If Enoch Light really did mimic LW, that would make me not an Enoch Light fan. I avoid using Enoch Light material on the CD's that I create. Billy Vaughn, Lawrence Welk, some of the other bands of the day, but mainly country bands provide sounds and melodies I use to demonstrate the capability and short comings of Magnavox.
Jack Imel and his noise-makers give Lawrence Welk family recordings a unique sound. Then there was Richard Maloof who typically played tuba, but could play almost any instrument providing bass. Then Neil Levang and Buddy Merrill provided string accompaniment not really expected in LW recordings. Buddy was a banjo player and Neil provided his off-beat up-beat guitar riffs. Harpisord and accordian leads also add interest. Billy Vaughn made three early stereo recordings with unique sounds. "Blue Hawaii", "La Paloma" and "Orange Blossom Special" may arguably have been his best efforts, although Billy Vaughn never recorded a bad note. Then there is Mel Tillis who liked to have twin fiddles, one in each channel, then merge in the middle. And the kettle drums in Connie Francis's "I'll Follow The Boys". They start out in the left channel and move over to the right.
Post: # 2427Post 19&41 »
I like Jean-Luc-Ponty's Individual Choice album, specifically the third cut, In Spiritual Love. It's a good one to run nice and loud.
Post: # 2438Post electra225 »
I made a CD with Red Nichols, Rafael Mendez, Al Hirt and a couple other trumpet players. My wife's favorite. She enjoyed that thumb drive you sent a few years ago, maybe more than I did. She is not a Harry James fan for some odd reason.
Post: # 2439Post 19&41 »
Fortunately not much of Harry on the drive. Individual Choice should be on it though.
