I"M BAAAAACK!!!!
I"M BAAAAACK!!!!
Post: # 21663Post electra225 »
Wow! What an adventure this has been. I had a combination of things that prevented me from logging onto my own forum. First, I was using Trend Micro for my security. When I started the forum, I had to disable it because it was causing an issue. I don't remember which issue, specifically, but it might have been log-on issues. Then, I cleared the cache on my desktop browser, Edge, and on my phone browser, Chrome. The great young technicians at Mark's shop took care of my phone. I managed to fumble thru doing my desktop computer, with Paul's tutelage.
Mark may make a blurb to this effect, but I strongly recommend that each of you clear the cookies on the forum. This is done at the prompt at the lower right corner of the index page. Then do that for the browser on your computer and on your cellphone if you have used it to access the forum. Then clear the cache on the browser on your computer and your phone as well. I had never done this before, never really heard of cache before. I have the procedure down on a paper so I can use it for reference.
It sure is good to be back on the forum. I want to thank Bill for his leadership during the migration of the forum.
