WTB brass trim for 59 imperial
Forum rules
- Hydrolastic
Hello, I have realized that the imperial is missing some of the brass trim around the speakers. just one piece the opposite side of the one in the picture picture is not my console if you have one let me know. I will pay a good price for it.
Re: WTB brass trim for 59 imperial
A suggestion would be to see if you can find a brass channel of some kind and make a new trim piece. You might even be able to use an aluminum one, then paint it to match acceptably. It would certainly be better than nothing. That piece might be on the verge of being unobtanium.....
Good luck!
Agreed on the aluminum, with some yellow lacquer. Lots of "brass" trim was alum., either anodized or lacquered.
