"80 cents a squirt......"
"....ten squirts to a quart". That is how the Mini dealer sells oil now. They buy it in bulk, Valvoline full synthetic, 5W30. The price it out at "60 at $.80=$48.00". I got the oil changed, and now I'm putting a coat of wax and some "Back to Black" on the trim. The thermometer on the patio where the sun hits it says 105 right now. That is probably ten degrees too warm. It's that time of year....
Re: "80 cents a squirt......"
Box up some of that heat and send it along to MI. I'll send you some rain in return.
It seems to be getting hot early down here too.
