landing craft
landing craft
Does anybody know about WW II landing craft? We just found a photo of my late uncle on the boat he later drove on D-Day, and online sources don't show me a similar model.
Re: landing craft
Oops. Forget that jpg images don't work.
Re: landing craft
.jpg images should work. If your image is a file on your PC, use the 'add files' feature below the reply window to choose a file from your computer . I've just tried it to make sure it can be done.
- file.jpg (4.42 KiB) Viewed 2805 times
Re: landing craft
Try again.
Re: landing craft
I think that may be a landing craft, tank. Here's some pictures to compare it to...
https://www.navsource.org/archives/10/18/180709.htm
Re: landing craft
That's it! I had started looking for LSTs but all the photos found had different bows. That does match the photo. Thank you. Now I need to search on his hull no.
Re: landing craft
And here is LCT 590, which appears to be Wesley's boat.
http://www.navsource.org/archives/10/18/180590.htm
Re: landing craft
Glad that worked out for you. Bing helps find things like that. Just enter what you're looking for and go to "images". I found a picture there that belonged to the series.
- Hydrolastic
Re: landing craft
Wasn't the landing craft built by Hinckley? They had GM engines. There were a couple of those here in seattle. I loved hearing the pneumatic starters and the sound of a running 2 stroke diesel.
Re: landing craft
The online piece on them said they were built in Quincy IL then sent to New Orleans.
- Hydrolastic
Re: landing craft
Hello All, Higgins was the landing craft company, Here is the sound of a GM 2 stroke diesel startup at 2:00 minutes and they sound even better with a marine wet exhaust system https://youtu.be/F3T9hVWYazA?si=YkaCysPpwQNLn2q0
Re: landing craft
We've got a 471 in our local historic schooner in TC.
Re: landing craft
Here's the extract on the builder of the series that Chris identified.
Landing Craft Tank (Mark 6):
Laid down, 6 September 1943, at Pidgeon-Thomas Iron Co., Memphis, TN.
The Higgins yard was made over into the National WWII Museum.
