Garrard scale measure
Post: # 20889Post walyfd »
Years ago, I rebuilt a garrard type a changer for a friend. Well he called tonight about 33/45 vs 78 weights.
Here's how I do it. Level the arm at 90 degrees. Remove all tables and set the scale in this spot. The scale level is about the same as the inner and outer tables assembled.
Center the arm on the scale and adjust drop weight.
Re: Garrard scale measure
Post: # 20893Post TC Chris »
What kind of arm bearings (vert, horizontal) does the Type A have?
Post: # 20919Post Hi-Fi-Mogul »
I use the same method of measure.
