Phooey...
Phooey...
Post: # 19231Post electra225 »
Every time I try to get onto the forum lately, I have to log on again. It has forgotten to remember me..... ;) :roll:
It only happens on my desktop, the cellphone is fine.
I use two-factor authentication to log on to the forum and on the ACP, so I have to fire up my cell phone, open the security app, get the code, enter the code on the forum, then log on. Not something I want to do every time. Other members have mentioned this to me as well as something they have experienced. I use Edge browser, since that is what the forum software recommends. I NEVER use Chrome. If this happens to you, clear the cookies off your browser and also clear the cookies off the forum. You can do that at the bottom of the home page. If you make the right selections, it won't affect your log-in. If you use two-factor authentication, it won't change that code either, so you don't have to do it again. I use two-factor authentication at work and like it. Nobody can get somewhere they can cause mischief. ;)
tasar
Re: Phooey...
Post: # 19240Post tasar »
Brings up a good point, does the site only "see" logons to count or just what ? I never "auto" log to any site ... something about passwords in the space called "cyber".
Re: Phooey...
Post: # 19243Post William »
I'm with you, Dave, I never have any site remember me.
Re: Phooey...
Post: # 19257Post electra225 »
The forum software will count the number of people who have accessed the forum, "online users". It also counts the number of posts. This is a setting I made. It doesn't actually count the people who log on, but it lists them at the bottom of the home page, on the left side. If you want the software to "remember" you so you don't have to log in each time you get on the forum, there is a setting when you log on for that. This has always worked well for me, unless cookies on the browser start making that feature go wonky.
Re: Phooey...
Post: # 19271Post 19&41 »
Gee Greg, you too? :lol:
Re: Phooey...
Post: # 19274Post electra225 »
It sure happened the other day. I hadn't logged on since we did the updates. Deleting the cookies seems to have done the trick. Are you still having trouble?
Re: Phooey...
Post: # 19275Post 19&41 »
When I delete the cookies, it doesn't do it the next time. Then it starts in again.
Re: Phooey...
Post: # 19276Post electra225 »
IIRC, you use Firefox as your browser. Have you tried using Edge or Chrome to see if this problem persists? This would tell us whether it's your browser or something else that is giving you grief.
Re: Phooey...
Post: # 19277Post TC Chris »
Just for info, I am using Firefox with no problems at all. It logs me in automatically when I click on the link. No fussing.
Re: Phooey...
Post: # 19285Post electra225 »
This has been a chronic problem for Rex. I'm trying to "divide and conquer" to eliminate possible causes.
Re: Phooey...
Post: # 19287Post 19&41 »
I have used chrome with the same effect. I'v pretty much given up on being able to access the site without having to log in every time. It even does it if I return to my inbox to check different thread replies.
Ken Doyle
Re: Phooey...
Post: # 19291Post Ken Doyle »
I use two machines, and haven't had to log in to this site for a long time.
Windows 10 / Edge
Windows XP / Chrome
Re: Phooey...
Post: # 19294Post electra225 »
I run Win 10/Edge on the desktop and Chrome on my cellphone. Other than the incident I cited, I've had no trouble. Rex has had this issue chronically for some time. I don't keep up on "maintenance" like I should. I let my inbox on email accumulate 300 posts before I clear them all off. Might be something I need later, which never happens. When I get a minute to get with Mark, I'll put this matter on the agenda. There has to be a fix.... ;)
