My rant about tube sets...
This latest RCA I got in a nutshell explains why I don't like tube sets ... I tested all the tubes on my jackson 49 tester , two of the 6BQ5's are original and of course weak they are dated 48-62 ... the other channel has wonderful realistic lifetime tubes ... they test good ... but they are known to be junk ...one preamp 6QF7 is weak .. In the amplifier I totally recapped and checked all the resistors for drifting all were in specs except one 470 ohm was reading 520... the radio chassis I replaced all the caps I could , had to order a dozen .047 400 volt caps the chassis is loaded with them..when first playing the volume is OK , then as about 1/2 hour goes by , the volume is gone, the station has drifted off station ...turn the volume to max just to hear it across the room... the phono is actually louder than the radio... which is normally the opposite as the radio should have one more amp stage ... so is this the caps? the tubes? ... 6BQ5 are running 25 bucks a pop, 6QF7 runs the same price... the radio has one 12AX7 as a phase inverter .. those are $20+ a piece... I could dump over 100 bucks just in tubes and not correct any issues on the set , Tubes are getting expensive and in some cases surpassing semiconductors in price... Tubes sets are cool for nostalgia, but I am a child of the 70's ... its got to be loud and rattle the windows ... push pull 6BQ5's just don't do that... the motorola I had with the 6V6 outputs was the closest to real volume output I owned ...every other tube set ... meh... OK rant over
Re: My rant about tube sets...
I struggle too with tube stuff, not that I like SS any better. My biggest struggle is with the tuners, or any stand alone radio. Give me an amp, and forget the radio. Having said that, I have a couple of tube consoles that will shake and rattle the walls. The Magnavox Big Imperial will do that as well as the 1956 Magnavox Berkshire. I'm guess the Motorola in the Drexel cabinet will too if I ever get around to rebuilding it.
Before you get too excited, let's start out with directed tests and some guessing......
Are you sure the function switch is clean and not causing your problem. Those little buggers can drive you nuts chasing your tail. Then make sure the tube sockets are clean. I wouldn't worry about the tubes right now. Make sure all the controls are clean, any RCA jacks involved are clean. I've seen tubes that test weak that will work just fine in the circuit. If the audio starts out good, then fades, I would really suspect a connection of some kind, function switch, speaker switch, some control being dirty and making bad contact when it warms up. A good way to see if heat is an issue would be to cover the chassis with a cardboard box and let it get good and warm. I would replace capacitors and any out-of -tolerance resistors then see what you have. There might be a member of this forum who might be kindly disposed to sending you some of the tubes you need. Output tubes of any description will be spendy new. AES had the best pricing on new reproduction tubes. Good luck.
Agreed that it's important to check out other sources of failure before blaming tubes. Tubes are actually fairly durable, and the best test of a tube is in-service function. Tube tester results can tell us when it's dead or shorted, but if in works in the set, the tester's results are not important. Tube circuits are easier for me to figure out.
I hear you Bill ....tuners suck... unless you have the proper equipment specifically to service FM , you are not going to fix it...as stated in another thread , this RCA does exactly what that phonola I have does ... the stereo light comes on while the tubes warm up.. and as soon as the radio starts working it's off and never comes back on...I will not fiddle with any of the 67khz, or the 19khz or anything to do with the MPX section settings , messing with them will get you in deeper with lousy performance
- Conelrad
The Deity of your choice help you if you ever tied into a pre-war Hammarlund Super-Pro wake-up resto. Just the tube compliment would haunt you...
Their beauty fades with age, as all receivers do. However, they can be brought back to perfection with a bit of diligent work and proper parts replacement.
I've done plenty of them over the years, and everyone is really impressed just how good a rack-mount beast of a radio can sound with a proper speaker system.
Push-pull 6F6's in triode mode, driven by another 6F6 in triode mode, coupled to an variable bandwidth IF system from 1500 Hz to over 16kHz.
Anyways, they sound really good on an AM station from LW to HF, with no restrictive modulation to begin with.
Can yo see I'm a fan?
DG
DG
The only true way to service a tube set is to connect it all on the bench and power it up while under load and heat ... resistors / tubes / components can check fine at room temp and drift or fail under load or heat...tubes can check good for a couple mins on the tester , but you will get the real story during use... I had a 12ax7 out of the Motorola test great on the jackson , but once playing the sound started to fade and sound tinny , pulled the tube and stuck it in the tester while still hot ... had about 30% conductance compared to 80+ while cool
Did you ever try to cover the tube while on the tester to see if it fails when it gets hot? My stepdad used to do that all the time when he was working on TV sets. Tube substitution actually works best with TV work, but if you wanted to sell the customer an expensive tube, that method worked pretty well.
Try working on a Concert Grand or Imperial with everything connected and on your bench. It's the only way to get a good test, like you said. If it was easy, everybody would be doing it......
I've been thinking about pulling the trigger on a TinySA.hermitcrab wrote: ↑Wed Dec 20, 2023 8:10 pm I hear you Bill ....tuners suck... unless you have the proper equipment specifically to service FM , you are not going to fix it......I will not fiddle with any of the 67khz, or the 19khz or anything to do with the MPX section settings , messing with them will get you in deeper with lousy performance
https://www.amazon.com/Seesii-Inch-Tiny ... 5XT7B?th=1
https://antiqueradios.com/forums/viewto ... lit=tinysa
https://antiqueradios.com/forums//viewt ... 8&t=407327
I enjoyed the ARF links. Let us know about your experience with the SA.
you certainly need a lot of bench space that is for sure...I have done it with my astrosonic imperial ...electra225 wrote: ↑Thu Dec 21, 2023 8:19 pm Did you ever try to cover the tube while on the tester to see if it fails when it gets hot? My stepdad used to do that all the time when he was working on TV sets. Tube substitution actually works best with TV work, but if you wanted to sell the customer an expensive tube, that method worked pretty well.
Try working on a Concert Grand or Imperial with everything connected and on your bench. It's the only way to get a good test, like you said. If it was easy, everybody would be doing it......![]()
Users browsing this forum: Google [Bot] and 4 guests
