Cell Phones!
Cell Phones!
Post: # 1722Post William »
I'm facing a decision, one that I do not want to make mostly because I hate change. My good ole' reliable Tracfone will die at the end of the year when 3G goes away. So, I need to do the forced upgrade. It would made sense to upgrade to a smart phone, but I really do not want one. I like my flip phone, I only use it as a phone and I hate typing on glass as I do that now with an iPad. What do you all have and use, and can you give me some advice? Thank you in advance.
Re: Cell Phones!
Post: # 1723Post Hi-Fi-Mogul »
Hi Bill,
I'm in the exact same situation.
From my reading, 4g LTE
networks will be supported in 2022 and
forward.
TrackPhone (sic) has some $30 4G flippers,
but you may have to look around for one in
stock.
https://shop.tracfone.com/shop/en/tracf ... lip-l125dl
The "5G only" hoopla is probably to get a lot of new
phones purchased by people who don't need to.
https://tracfonereviewer.blogspot.com/2 ... hones.html
MEZLAW
Re: Cell Phones!
Post: # 1724Post MEZLAW »
I have a good friend who is a lot like yourself. He had a flip phone and upgraded to a new phone about 2 months ago. He could not get used to the "smart" phone and turned it in for another flip phone. Verizon still sells them. I also have Verizon so I'll give you my opinion here. I just picked up 2 new smart phones, they took some getting used to. My first smart phone lasted 5 & 1/2 years. I can't believe how much they have changed with this new one. I stick with the android operating system and do not use the I-phone. If you go with Verizon, make sure you go to a corporate store and not a franchise store, there is a big difference and you WILL regret dealing with a franchise store.I had to go back to the store when I needed help. Don't waste your time trying to get help by calling Verizon, I could write a book on their poor customer service! Are you a veteran? I get a healthy monthly discount because I am a veteran. That is another difficult process to got through, especially if you served many years ago. The old records are not available and you will need a copy of your DD214 which you will need to scan and upload.
I've been a telephone man/telephone engineer for 51 years and also an authorized Samsung dealer for the business telephone systems. These so called "smart" phone are not phones at all. They are very small computers which have a very poor telephone feature. This is professional opinion others may disagree! They are the "Swiss army" knife of electronics!
MEZLAW
Re: Cell Phones!
Post: # 1725Post MEZLAW »
I'm glad you brought up 5G. While my new phone is 5G capable, I remain on 4G. I will not go into the reason here because it can and will become political. We do not want that!
Re: Cell Phones!
Post: # 1726Post electra225 »
I have a Samsung Galaxy smart phone Trac Fone. I believe it was something like $ 40 at Walmart. Costs $19.95 every 90 days for basic service, which is what I buy. I like it. I can use it at work to check the forum, which is where I am as I type this. I don't believe you would go wrong with a Trac Fone. Good luck
back-2-mono
Re: Cell Phones!
Post: # 1729Post back-2-mono »
LG, 4G flip-phone fan here!
I don't need to lug around a computer in my pocket simply to make or receive phone calls..sheesh.
Re: Cell Phones!
Post: # 1735Post 19&41 »
I'm on Tracfone and I bought a Samsung A10e. It is a decent phone and has excellent coverage. it has Google maps with directions that means I seldom get lost nor have to not go somewhere because of difficulty in finding it. I was able to find a decent shock absorbing case and snap in holster for it. It also has bluetooth that my car uses for answering and making calls hands free. They have them new and refurbished. I pay $20 a month for my tier of service.
Re: Cell Phones!
Post: # 1738Post William »
Thanks Guys, you have been most helpful. I learned today that LG is no longer making cell phones. So, I guess, that leaves Samsung and Motorola. I'm sure there are other companies out there, those two just came to mind. I have tried to use smart phones before both to talk and listen on and I have trouble doing either. I may go for a flip phone, but still have time to think about it. Anyone else have an opinion I would love to hear it.
Re: Cell Phones!
Post: # 1748Post TC Chris »
As a registered troglodyte, I'm still a flip-phone guy. Verizon informed me that I had to get a 4G phone to replace my old LG (3G). The new flip version from Verizon is an Orbic, which doesn't work quite like the old LG (of course; they have to change things to justify new versions).
The whole family insists that I must have a smart phone. But like Bill, I use mine as a phone. The computer sits on my desk at home or at work. I don't want to join the crowd of folks staring at their phones.
The radio informed me today that the old rule that even a discontinued phone could call 9-1-1 is not true for 3G phones. They'll be dead.
Re: Cell Phones!
Post: # 1753Post electra225 »
I don't live on my phone. I don't use near all the features the phone has. I haven't figured out how to put "Begin the Beguine" on as my ring tone. I use it as a phone, and I monitor the forum on my break and lunch hour at work. I fought tooth and toenail not getting a smartphone. I have to admit I enjoy mine. I can hear it, I can answer it. I don't have to do that silly swipe to answer it, this one lets me set it so I can touch and answer. I never did learn how to swipe correctly. It works semi-okay on the forum. I don't know. My wife has to get a new phone, since hers is from 2004. MY old one was from 1998. I find this phone easier to use than my old flip phone was, honestly. The thing you might consider about a cheap Trac Fone smart phone is that if you don't want to use all the features, you won't have to. If you decide to tinker and like it, then it's there if you want to use it. My two cents.
Re: Cell Phones!
Post: # 1754Post 19&41 »
For them that has a smartphone and fat fingers, I recommend a stylus. if I have to do any typing on mine, I must use it.
Re: Cell Phones!
Post: # 1755Post electra225 »
I use strong language while wearing out the backspace button on my phone, just like I do on this desktop PC. ;) :D
Re: Cell Phones!
Post: # 1756Post William »
Thanks again guys!
Re: Cell Phones!
Post: # 1777Post hermitcrab »
I avoided the smart phone as long as I could , said I would ever get one , yet I do have a Tracfone samsung galaxy 7 and at only 15 bucks a month for service it is fine with me ... all my friends pay 100 - 200 a month ... only down side with tracfone is if you use your phone for a GPS it will suck your 1 GB data dry in a day or two..., I only turn mine on when I get close to where I am going and it suits me fine
Re: Cell Phones!
Post: # 1782Post 19&41 »
I frequently get sale Emails from Tracfone. They are still offering a flip type phone. You might have a look there. Their prices for service are pretty nice too.
Re: Cell Phones!
Post: # 1791Post William »
I am considering Tracfone again. The phone I have now is a Tracfone flip. I like what I see in there smart phones, but still not sure I really want a smart phone. I have also considered Consumers Cellular.
Re: Cell Phones!
Post: # 1802Post hermitcrab »
Unfortunately I said the same thing ... smartphones are nothing but a form of dopamine for you...that is why people are constantly on them...I said I would not get hooked ... but alas a did ... BUT .. I do not live on it... and at 15 bucks a month i will live with it... but some of the apps are really convenient... instant lookup of information .comes in handy.. all my friends at work gotta have the latest and newest Apple 12... at only 1000 bucks what a deal.... then pay 100 - 200 a month for service ...while Apple updates them into obsolescence so you can buy the next one... oh boy count me in... not...Google has joined in on the update them until they don't work anymore bandwagon ... just yesterday I got a update for my chromebook... now videos are all blurry and it is slower... thanks Google...
Re: Cell Phones!
Post: # 1813Post Firedome »
Smartphones are DESIGNED to hook you... resistance is futile!
I'll keep my flip phone until they pry it... well, you know...
Re: Cell Phones!
Post: # 1818Post 19&41 »
My smartphone is a tool. I use it as such. On occasion I will go over my Email inbox while waiting at the doctors or barber. I use it to get driving directions when I need them. I use it as a phone as well. The rest of the time it is off, with a charged battery at the ready.
MEZLAW
Re: Cell Phones!
Post: # 1831Post MEZLAW »
Maybe a little off the original topic, but what gripes me about these "smart" phones is the number of people trying to text while driving or reading a text. You can find these easily, the car ahead going slow and weaving, or the one sitting at a green light!
