VM 162
VM 162
Post: # 1620Post William »
This a test to see if I figured out the photo thing.
Re: VM 162
Post: # 1621Post William »
It worked! So, this is the amp from my VM 162 speaker that matches the VM 557 potable record player. Now that I know how to do the photos, there will be more to the story.
Re: VM 162
Post: # 1628Post electra225 »
Job well done, Bill. I had confidence. I look forward to not only the story, but also more pictures. :D :D
Re: VM 162
Post: # 1648Post William »
Just so everyone knows what a VM 557 and VM 162 looks like here are photos from Gary's site.
https://www.thevoiceofmusic.com/popup_p ... &TITLE=557
https://www.thevoiceofmusic.com/popup_p ... &TITLE=162
Re: VM 162
Post: # 1650Post Hi-Fi-Mogul »
Bill,
I restored a 557 several years ago.
Besides weighing a ton for a tabletop,
it sounded amazing.
I have also had a late 1950's V-M powered speaker
with the single 6V6 and power tranny.
It had 2 x 8 inch woofers and a crossover tweeter.
Also amazing sound.
You better get to work, ha ha !
Re: VM 162
Post: # 1652Post hermitcrab »
I like the deco look of it ... that grille is killer...
Re: VM 162
Post: # 1663Post William »
Elton, the grille is cool and it is heavy. Not something you want to move often.
Mogul, you said had? Does that mean the amp/speaker is gone? Do you remember the model number? I'm trying to figure out what amp and speakers are in the different VM amp/speaker units.
Re: VM 162
Post: # 1664Post Hi-Fi-Mogul »
William wrote: ↑Fri Sep 03, 2021 11:48 pm Mogul, you said had? Does that mean the amp/speaker is gone? Do you remember the model number? I'm trying to figure out what amp and speakers are in the different VM amp/speaker units.
Bill,
It was Model 165 amplified speaker.
Sams photofact 423-23.
Re: VM 162
Post: # 1665Post William »
Thank you!
Re: VM 162
Post: # 1670Post electra225 »
Very nice, Bill! The only thing I own by VM is my old tape recorder. They get a lot of sound out of a 6X9 speaker. I'm really impressed with VM and the build quality they had. Right up there with Magnavox from what I've seen. I hadn't seen much of their stuff until you started scoring a few.
