Shango working on Fisher with SMD
Discussions of anything Fisher. Consoles, components, speakers and general history of Fisher.
Post: # 17369Post hermitcrab »
sounds bad for fisher owners if these IF cans can develop SMD https://youtu.be/w5yyko1hzVg
Re: Shango working on Fisher with SMD
Post: # 17370Post electra225 »
I have been watching that video just this morning. Magnavox uses similar IF transformers in some of their stuff as well. I have been lucky. This may also explain some of the funkiness in Magnavox tube tuners with their drifting and not being able to align them so the dial is accurate. Silver mica migration is one of my main gripes with Zenith tuners. I'm beginning to wonder if most of the IF transformers in console stereos may be infected with SMD in even a small way..... :oops: :roll: Not enough to make noise, but enough to affect gain.
In the video you mentioned, Shango is using variable capacitors to find the value of the mica caps in the IF transformers. In that particular tuner, the values appear to be critical. I understood they were fairly general. Perhaps a conversation about everybody's experience with this might be interesting..... ;)
Post: # 17470Post Motorola minion »
Have not yet seen video of Fisher but yes, I have parts chassis now so fear not Fish-heads :D
Until the internet (my case 2011) I never knew what this was. I junked a wonderful-sounding Silvertone 1962 clock AM-FM radio. I had NO IDEA there was a capacitor in the base of an IFT :x .
The dawn of knowledge was found in a Zenith C845 AM-FM table radio (Interlude) with near constant thunder crash sounds on FM only c/o SMD, after going bananas cleaning and working around the band switch and tube sockets, I found an online drawing showing the circuit schematics for most of the common "big can" IFTs Zenith used in tube radios. https://antiqueradios.com/forums/viewtopic.php?t=30277
I nailed which can it was by grounding to chassis the grid of each IF tube, intercepting where crackle gets amplified. In my case, the value of preceeding stage IFT and even the as given as 110 pf, so I ordered the mica dips labeled 110p,111 or 110 mmf. The issue was solved working on just one can!
A helpful Ex-Philco employee on VK helped me locate a cap value for an FM ratio-detector transformer in a rather plain tube 1962 Philco console that wasnt even multiplex equipped.
Post: # 17471Post Motorola minion »
The capacitance value appears critical because Shango has better signal generators and frequency counters than most of us. :roll: He is taking the high road to proper determination of value, in absence of a swapping in whole new IFT from JW Miller or Merit, the conventional way to repair these. Parts lists and schematics cannot be counted on.
Schematic diagrams of some manufacturers and some Sams Photofacts DO show this value but most do not. One method is to disconnect one winding lead and actually measure capacitance of the suspect cap in base, expect it to fail when even a small DC voltage from the cap checker is applied. My DMM is no help here, it will measure less than 1 nF (.001)
I miss the older IF cans with fixed coils and easily-replaceable trimmer caps. NO SMD in those! :D
