Testing power transformers
Post: # 1473Post Hi-Fi-Mogul »
Would some of you all post a primer on
how to go about testing a power transformer in
a hi-fi using only a dmm or analog meter ?
I cannot find my notes I compiled on this basic task,
and I'm sure newbies would benefit.
Could it be placed in the "Getting Started" topic section ?
Thanks !
Re: Testing power transformers
Post: # 1478Post electra225 »
Check "Getting Started", Mr. Mogul. Hope that helps.
Post: # 1486Post Hi-Fi-Mogul »
Thanks so much Greg.
I'll copy that good info into my troubleshoot files.
Post: # 1490Post Hydrolastic »
Thank you, Mogul, Greg. I am half heartily looking for stuff to be able to get to the point of checking a console out without it blowing up. Super afraid of electrocuting myself with all the warnings out there. Still would like to be able to. Before the consoles started showing up i picked up this meter. I would like to know if it is something i can use to measure things. Like transformer outputs like in your post. One thing is you said to use a digital voltmeter DMM but i have to say i don't like to use these because of the flashing on and off and variable readings sometimes, it drives me crazy. i would prefer analog meter everytime. But i know nothing so idk if that sounds stupid to you guys. So far i have only measured stuff on old cars. Here is the meter. Sencore FE-20
Post: # 1491Post William »
My first thought, it's a different type of VTVM. Maybe a more modern one. Since I was not sure I used Mr. Google to see what I could pull up.
Here is the best write in your meter.
https://www.antiqueradios.com/forums/vi ... 8&t=169920
My guess seems to be correct, it's a modern solid state VTVM that is capable of doing more. So, yes, this will be a good tool for you to check just about anything you want to check. I'm jealous, now I think I should have one. And please, never think anything is stupid. We are all at different levels of experience here, but, there is always something out there that we still need to learn. Never be afraid to ask questions!
Post: # 1503Post electra225 »
It's an electronic volt ohm meter. Perfectly usable for working on an old stereo. I can understand being wary of certain procedures. Being afraid can get you into trouble. Being aware and educated might be a more worthwhile course. Not knowing something is not a crime. That is why there are more experienced people here more than willing to help you. The only stupid question is the one you don't ask, then not having information gets you into trouble. Don't be afraid to ask if you are not sure. That is what we are here for. I might suggest that the schematic is your best friend when it comes to dealing with voltages in a chassis. The schematic is the road map of how voltage flows thru the circuits. Always follow your meter when you dig into a chassis. Good luck.
