Gene Pitney
Gene Pitney
I was looking through the albums and came across gene Pitney's greatest hits...of course he has been gone for a while .. I completely forgot I had this ...24 hrs from tulsa, town without pity, and don't forget , the man who shot liberty valence it was nice to hear it again , I recorded it to the computer to save it ... just in case... then of course I had to watch the movie ... again...
Re: Gene Pitney
I always liked Gene Pitney. He did a country album with George Jones and one with Melba Montgomery. Pretty good albums.
- back-2-mono
Re: Gene Pitney
I too have that lp. Think I'll dig it out today, throw it on the Nitty Gritty RCM and give it a spin.
Re: Gene Pitney
Did you ever get your Jim Reeves record?
- back-2-mono
Re: Gene Pitney
Yes I did. Not only is it a great and soothing record, but it's also one of the best sounding records in my collection. Made me dig out a couple of his 45's and give them a spin too..Guilty and He'll Have To Go.
Thanks for the recommendation.
RCA Record Geek Alert: The icing on the cake is it's a '1S' pressing..both sides!
Re: Gene Pitney
Educate me on the significance of the "1S" pressing.....
They called Jim Reeves "The Perry Como of Country Music" for a reason. I'm glad you enjoyed the album.
- back-2-mono
Re: Gene Pitney
Back in the day, all RCA lp's had a stamper number etched into the vinyl in the run-out area just after the matrix number. The number indicated the stamper number and the 'S' stood for stamper.
A 1S indicated that the record was pressed using the very first stamper manufactured to press that record. The lower the number, the better the quality will be for that particular record due to mint master tapes.
RCA was very picky about the sound of their records back then. Once a stamper was worn out, they would make a new one for future pressings.
The attatched picture is from the Jim Reeves lp I just received...
- IMG_9024.JPG (104.76 KiB) Viewed 2894 times
Re: Gene Pitney
Thanks, Gary! I learned something. I'll check my records......
- back-2-mono
Re: Gene Pitney
Great! Check your copy of The Intimate. Curious as to what generation your pressing is.
Re: Gene Pitney
Is your Jim Reeves record mono or Mono Dynagroove?
Does your record say LPM-2629 or LSP-2629.
- back-2-mono
Re: Gene Pitney
mono
cat # LPM-2216
side one matrix # LZ WP 2629 1S
label: long 33 1/3 play
cat # LPM-2216
Re: Gene Pitney
"Mono" is better than "Mono Dynagroove". So you got the good one.
Re: Gene Pitney
The things I never knew about the stamping of records, what great information!
