Never Anything Easy Nor Simple
Post: # 15262Post 19&41 »
My Explorer Limited put up a check engine light. I found, with my code reader that the driver's upstream o2 sensor was affected. I got a new one and had my great nephew replace it. He had some trouble getting the connector to seat and lock but he got it together. I started the engine and the CEL had dissapeared. However, when I drove the car it came back. The code reader showed all the o2 sensors were either failed or pending failure. I decided the only way forward was to take it to the dealership palace and have them diagnose it. That was yesterday. I called them today to check on it. the service advisor said "I have good news and bad news" She said "The tech had just finished the diagnosis. The bad news is that the problem in with the PCM. That is a part that Ford has obsoleted and is no longer available." As an added bonus, they are not available at the major auto parts stores (through Cardone Mfg.)
Re: Never Anything Easy Nor Simple
Post: # 15264Post electra225 »
Wonder if anyone rebuilds them?
Post: # 15267Post TC Chris »
Click and Clack were big advocates of the black-tape method.
Me, when my Ranger recently flashed its light, I took it in for diagnosis. The shop reset the device, showing an O2 sensor issue. It stayed off for them. I drove away. It came back on. I made a nice little piece of cardboard to keep the light out of my eyes until I could get back into the shop. Black tape seemed too sticky. I reached for my cardboard and started the truck again. The light was off and stayed off. So maybe just threatening to ignore the light will make it go away.
Post: # 15272Post William »
My 1994 Ford Ranger's check engine light comes on all the time. When read, it says there is a problem with the power steering. OK, the fluid is full and the PS is steering the truck. The code has been cleared several times but eventually it will come back on, then off, then on, then off. I now choose to ignore it.
Post: # 15281Post electra225 »
I found this outfit, courtesy of "Mr. Bing". I know nothing about them, but they say they sell Ford PCM's. I hope this helps, at least gives you a place to start. ;) ;)
https://www.fs1inc.com/ford-pcm-ecm-ecu ... 0(Rebuilt)
Post: # 15283Post 19&41 »
I'm looking into a repair place. Thanks Greg, but The modules they have are a bit pricy. I also have to work out getting to work while the module is sent out.
Post: # 15289Post 19&41 »
Here is a vendor I'm considering. https://www.ebay.com/itm/374197620984?f ... R9zV6pmZYg
The dealer run down also states that the car fails emissions inspection, so ignoring the CEL is not an option.
Post: # 15308Post hermitcrab »
Give it the Shango066 treatment... he repaired those ford PCM's on his site a few times... didn't look that bad...
Post: # 15312Post William »
I found a few repair suggestions on YouTube on how to repair the ABS module on a GM the S and T line. I thought, what the heck and I tried it. Worked like a charm and saved me between $500.00 -$1000.00.
Post: # 15325Post TC Chris »
William wrote: ↑Sun Jun 18, 2023 7:06 pm I found a few repair suggestions on YouTube on how to repair the ABS module on a GM the S and T line.
OK, I'll bite. What's the "S and T line"???
Post: # 15327Post William »
The "S" stands for 2-wheel drive, and the "T" stands for 4-wheel drive and pertains to the Chevy/GMC line of small trucks. S10 p/u, GMC Jimmy, those GM vehicles.
Post: # 15330Post 19&41 »
I work on circuits of this detail at my job, but only with a set of manuals detailing the function of each portion of the circuit. I have nothing more than a block diagram of the PCM in my literature on the unit. One mistake and my car goes from my primary vehicle to something that is able to roll onto a flatbed to go to the scrapyard. If there is a place that repairs them with a known good track record, I'd rather take a chance with that.
Post: # 15332Post Firedome »
Early obsoleting of electronics makes vehicles of the '90s onward more difficult to keep running than those from around 1980 and earlier.
Post: # 15333Post 19&41 »
I'll wager there will be aftermarket suppliers rising to meet this need soon. They can handle the overhead on supplying this vital component.
Post: # 15347Post William »
Good luck, Rex and I hope it turns out to be an easy and affordable repair.
Post: # 15354Post electra225 »
I wager that auto manufacturers are obsoleting vital parts for internal combustion engine-powered vehicles so owners will be forced into buying an electric vehicle...... ;) :roll:
I have a friend who recently had the engine replaced in a 2002 Chevy pickup, a 4.8 Liter V-8. Just the rebuilt long block cost him almost $7000 from the dealer. I used to buy complete new 350's and 366's from this dealer for $1800 including a 50,000 mile warranty. The truck is still in nice shape. Lest you wonder why somebody would spend that kind of money on a 20 year old truck....... ;) ;)
A new one similar to it would be almost 80 grand! Plus, the old one is paid for. ;) ;) :D :D
Post: # 15356Post 19&41 »
Thanks, Bill. We'll see.
Post: # 15357Post TC Chris »
electra225 wrote: ↑Tue Jun 20, 2023 1:24 am
I cannot imagine paying $80K for a device to drive around, surrounded by drunk drivers, people chattering on cell phones, road-ragers, and the occasional kamikaze deer. The most I've ever paid for a vehicle was the $10K for my sweet Ranger.
Post: # 15360Post 19&41 »
For $80K it should be a house, not rolling stock.
Post: # 15361Post William »
I totally agree, Rex.
