In the manual for the Zenith Stroboscope changer, it says
that:
"To dismantle many components of this changer, a
slab head set screw wrench is required."
There is no specific description in the parts list
that says slab head set screw.
I could not find anything from an internet search,
to tell me what a slab head set screw is.
Does anyone have experience with this type of screw
and what they look like ?
Thanks !
Slab head set screw ?
Re: Slab head set screw ?
I Googled "slab head set screw". This was the first thing that came up. I don't know if this helps or not. I'll try McMasters-Carr next.
https://www.getfpv.com/m2x5-socket-head ... group+%231
If McMaster-Carr doesn't have it, you don't need it.....
https://www.mcmaster.com/screws/
Hope some of this helps. I've never heard of a slab head screw. Good luck...
Are there any odd fasteners visible on/in the changer? It may be an old reference for a renamed current fastener.
I have to remove the plastic faceplate of the changer,
to see what's there.
I had the same thought that these screws could not
be too unusual in design.
When I get to the changer, I'll report back.
I'm starting the amp checkout this week.
Users browsing this forum: Google [Bot] and 6 guests
