Multiplex adapter, Suspension springs, Molex connector
Forum rules
Post: # 13281Post electra225 »
I could use a good Multiplex adapter, the stand-alone kind. I'm not picky about brands, it just needs to be usable. I expect one may need a tune-up which is fine. I don't care if it is missing a tube. Let me know what you have and thank you.
I can also use three suspension springs for a Collaro changer.
And a Molex connector for power to the changer. The one that plugs into the changer.
Re: Multiplex adapter, Suspension springs, Molex connector
Post: # 14019Post electra225 »
Gary at VM Enthusiasts does not have a Molex connector like I need. I don't want to hard wire the changer. Does anybody have one they would part with? I'm pretty much done with this project until I get this figured out. Thanks for any help you can give. These Molex connectors might be a good 3-D printer project.
Post: # 14022Post Hi-Fi-Mogul »
electra225 wrote: ↑Sat Apr 08, 2023 8:30 pm Gary at VM Enthusiasts does not have a Molex connector like I need. I don't want to hard wire the changer. Does anybody have one they would part with? I'm pretty much done with this project until I get this figured out. Thanks for any help you can give. These Molex connectors might be a good 3-D printer project.
How about a photo of that male molex plug ?
Post: # 14023Post electra225 »
I took this with my phone. Not the best quality, so I apologize for that.
Post: # 14362Post Hi-Fi-Mogul »
Greg,
You need the male plug end, correct ?
Please note the plug in the photo is keyed.
Does it exactly match your female receptacle with
same key and wiring color sequence ?
Post: # 14382Post electra225 »
I have everything piled up in the shop right now. Thanks for your response, Mr. Mogul. Let me get a minute to go out and check. I THINK that is the right plug, but let me check for sure. :D
