Any insights on medicare plans?
need some advice ...My enrollment is coming up and I am getting hammered with phone calls trying to sign me up for a advantage plan... My money market guy says stay away from them as they don't fulfill their promises , and change the rules midway though the terms ...he told me to stick with regular medicare...any thoughts on this matter... yeas, nays.?
Re: Any insights on medicare plans?
I am being bombarded as well. I'm holding off til 70. My sister however uses BCBS's advantage plan and she's happy with it. Enough so, I will consider it.
I have a Medicare supplimental plan. With it and regular Medicare I don't have deductibles or co-pays. Advantage was not going to work for me, since I'm a cancer survivor. Seems like each situation is different.
I'm 74 and still working so I have avoided dealing with Medicare, except to sign up as required. I get insurance through work. But I have read that if you choose Medicare Advantage, you're stuck with it and can never go back to traditional Medicare.
I always defer to the U.S. govt sources, and they
are very well organized and informative to me.
Other people's opinions aren't necessarily facts. Ha !
So my opinion is that I don't believe any Medicare Advantage plan
can make arbitrary changes, because they are contracted by Medicare.
Rules and regulations are there for some control.
A phone call to Medicare will inform you about your money mkt guy's
statement and mine. [ : )
https://www.medicare.gov/sign-up-change ... h-medicare
There are two types of plans to choose from. One is Advantage, and it works like any regular "Work" type medical plan. It has deductibles, copays, and total out of pockets. It does include your prescription drug coverage and can include other things depending on which plan you choose, and there are lots of plans to choose from. The other plan is called a Medigap plan. Premiums are usually a little higher, and there are several plans to pick here as well. Plan "G" is the ultimate plan. The only deductible you should ever have is the Medicare part "B" mandated deductible. In 2021 I believe that is $203.00 for the year. If one chooses a Medigap plan, then you will also need to get a part "D" prescription plan. That is a separate premium and again there are many plans to pick from. The last I knew anyone needing to join Medicare has one year to shop around, try different plans, and see what works for them. Within that year is the time to join a Medigap plan if that is the direction you want to go. Medigap companies are fussy, and if you have a lot of health issues you may not get accepted after the first year. After the first year you will be required to answer a lot of questions, then it goes before underwriters to decide whether you will be accepted or not. During the first year of Medicare enrollment it is required by law that all companies have to accept you. The Advantage plan does not have that rule, they will accept you no matter what your medical conditions are. One thing to remember, there is an open enrollment period every year. It's from October and goes through mid December. During that time you can change levels of plans, or plans themselves, or companies. Please keep in mind, if you have a Medigap plan and switch to a different level Medigap plan, or an Advantage plan, or a different company, you might not be able to return to your original plan. All sound confusing, well it is and that's the way they like it. Advantage plans are the "IN" thing, and I'm guessing that is where the money is for the health insurance industry. And, I'm guessing some where down the road the Medigap plan will go away. There are honest health insurance brokers out there that have good advice. Most will try and sway you to go Advantage because that is where the money is, but you need to insist that they explain the "INS and OUTS" of both plans and then see what fits you and your budget the best. I chose the Medigap plan, as I would rather pay a little more in premiums than deal with the health care systems hoops when it comes to deductibles, copays, and total out of pockets. I hope this helped, and good luck to everyone who needs to make this decision.
