Music on SW
Discuss music and media, records, tape, CD's, reel-to-reel, cassettes, whatever. Artists and genre discussions.
Music on SW
Post: # 9338Post TC Chris »
Last night I got out a Zenith Transoceanic, an R-3000, to see what was on SW. Lots of religion, as usual. But also some music. At just above 6 mHz, an apparently syndicated show playing "Cruisin' the Decades." He played one tune per decade, moving from the 19-teens through the '50s as I listened. Good choices of music, and the early ones were in good quality audio. I just did a Google search and apparently it was part of XM radio, one of those for-pay services. But you can hear it for free on SW.
Re: Music on SW
Post: # 9341Post hermitcrab »
have to check that one out...
Re: Music on SW
Post: # 9349Post William »
Chris, do you have an external antenna running around your house?
Re: Music on SW
Post: # 9353Post TC Chris »
William wrote: ↑Sun Aug 21, 2022 10:38 pm Chris, do you have an external antenna running around your house?
I'm in Bay City right now. I was just listening with the T-O's whip antenna. In TC I do have a back yard wire.
Re: Music on SW
Post: # 9357Post William »
Thanks, Chris, I need to have an outside antenna of some kind. My SW reception is very poor with just the internal antenna.
Re: Music on SW
Post: # 9361Post electra225 »
I strung a wire inside the shop for an antenna. My shop is blessed with being located in perhaps the hottest radio reception area I have ever been a part of. I used wire out of a roll of phone wire I had. It is four colors. Almost 80 feet total length, running all four directions. It's not very neat yet, just there to see how it will work. I believe it is going to be a good setup for AM and shortwave. The funny part about this is that there is a high-tension line within 20 feet of the west end of the shop. The signal is stronger in the shop than it is in the house, farther away from that power line. For some odd reason, the old Grunow I redid is a better shortwave radio than my Hallicrafters SX-110. I'm going to get caught up around here, then see some evening if I can get some music on shortwave. Thanks for the heads up, Chris.
Re: Music on SW
Post: # 9368Post Motorola minion »
Thanks Chris! Ill have to see if the 1947 Berkeley Magnavox can get that, its my best working SW set. I'm working on a Zenith 7000 T-O, so once that's done I can confirm.
Using a whip antenna on the receiver is great when you're outside but inside a structure is touch and go, as my old boss used to say about spotty tv reception.
My antenna is stranded copper line, 20 gauge. Run is 120 feet between trees with rope/insulators, at 30 feet above ground and my drop wire is 20 feet from one end.
Re: Music on SW
Post: # 9370Post electra225 »
I had a longwire antenna in Missouri. That is the best method if you have room. I don't have room here, plus the HOA would be on me if they could see it.
Re: Music on SW
Post: # 9375Post Motorola minion »
electra225 wrote: ↑Mon Aug 22, 2022 8:35 pm I had a longwire antenna in Missouri. That is the best method if you have room. I don't have room here, plus the HOA would be on me if they could see it.
Due to many similar restrictions, I used many an indoor wire antenna that worked superb so long as it was not under a metal roof.
