Drafts?
Drafts?
Post: # 8560Post TC Chris »
I just typed up a 4th of July and it wouldn't send so I chose the option to save it as a draft. Now I can't find where drafts are saved. Ideas?
Re: Drafts?
Post: # 8561Post electra225 »
Are you trying to find it on your computer on on this forum? If you saved it to the forum, go to your User Control Panel. To find the User Control Panel, click on your username at the upper right hand corner of the screen. Click on "User Control Panel". There is a selection in the User Control Panel "Manage Drafts." Click on that and see if you find your draft. Good luck.
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 4 guests
