posting pics?
posting pics?
OK I'll admit up front that I'm as dumb as a rock when it comes to using PC & Mac computers. Am trying to post some promised pics on here, I see a place in the row of icons above to insert image link to URLs with pics, but no "Browse" feature to grab pics off my desktop as I normally do on the other sites I visit and post pics on... help?
Re: posting pics?
Below the white box where you post, you'll see a smaller blue box. It says "options" and "attachments". You click on "attachments". Your pictures or documents will come up. Select the picture you want, making sure it's no larger than 256 KIib file size. After you select the picture, you'll see an icon "place inline". Click on that, then hit submit. You should be golden.
Re: posting pics?
I have to reset my camera resolution. Went to post something and the photo is way too big and there's no option to resize it.
Re: posting pics?
test
Re: posting pics?
Blast... that pic is from another source, very small, but all the pics from my camera are + 256. Not real fun to have to re-size every time I want to post a pic, I'll be inclined to forgo that process being inherently lazy I guess.
Re: posting pics?
If you are using a phone to take pictures, you can reset your phone so the pics won't be so large. If you are using a digital camera to take pictures, set it for something like 640 X 320 and see what happens. If I set the file size larger, the pictures will be larger than the page. The one I posted of the Packard is set exactly at 256 MiB. You can see how big it is. Really too big for a car picture, but that will be nice when we are looking at a chassis someone is having trouble with. Every forum I know of has specs on how large a picture to post. Hang in there, Roger. We're all learning......
In the short term, open the picture you want to post. Right click on it. From the dropdown, click on "resize". It will give you options on what sizes you can get, and you can set it for whatever size you want, as long as it's under 256 MiB. This works in the short term until we get accustomed to what we have to do.
Re: posting pics?
Roger, if you would, try posting the picture you were having trouble with. The one I posted above was off my phone, which is a huge file. I eliminated the 256 MiB setting. See if it works for you.
Re: posting pics?
That's a nice looking unit Roger, thanks for sharing.
Re: posting pics?
Don't have a smart phone. Remember I"m a dinosaur. lol. My old built-by-my-son PC desktop running Windows 7 Pro has an ancient non-right-click (mono?) mouse. Have a 20 yr old Agfa digital camera I barely know how to use, it always takes pics about 800 to 900 Kb? No clue how to set pic size on it. Sometimes I think I'm that 2000 Yr Old Man. I'll try to repost the pic of the Rhapsod's guts.... Huh? it worked, but it's a 1.4Mb pic from Motorola Minion and I didn't re-size it... wassup with that?
- 20210403_125630.jpg (1.34 MiB) Viewed 5560 times
Re: posting pics?
I have a small chromebook I use ,any pictures i take with it are huge as well , but they will pop up in a editor right after taking them .. they are big like 1.5 meg size, but the editor gives me the option to reduce them , I just set the pixels to 480 x 480 and they always come in under the 256 limit to post...
Re: posting pics?
tried to post a pic of the Rhapsody amp, same size as the front panel pic from MM that worked, now the amp shot did. I did not resize anything... o idea what's going on, maybe now it will accept larger?..
Re: posting pics?
It was magic....
Re: posting pics?
Could be! If a site upgrade was made, then kudos to whomever!
What I did was add the pic and when status was green I just hit Preview then it showed up, then Submit without doing the "inline " step and it works... who knows, but if it works it works, all the pics are 800kB or larger.
Re: posting pics?
I would be that "whomever".
There is a line in an old Jimmy Dean song that says " I sure hope the guy at the switch ain't a drinker...."
I have the "magic button" I can hit and all kinds of "deleted" will break loose. I usually mess thing up when I use it, but even a blind squirrel will find an acorn eventually.
I'm glad it all worked out. I left the pictures large so they are easy to see. Most of us aren't teenagers and may appreciate the larger size. I suppose SOMEONE will complain, but I like them bigger and I have the "magic button"......
Re: posting pics?
Gee, let's see if this works... the Lafayettes I picked up for 9 bucks last week. One has a Realistic replacement speaker but they work.
- 20210731_075559.jpg (4.68 MiB) Viewed 5372 times
Re: posting pics?
You got a deal on those speakers. I like the carpet as well. Nice job on the picture.
Re: posting pics?
Well thnx v much for that pic posting upgrade, now I won't hesitate. Being inherently lazy,expending effort is always a consideration,
Re: posting pics?
Thank you for your participation and support.
Re: posting pics?
Computers and technology, I will never understand it but us old guys will take what we get when something works and we do not know why.
