I washed the Chevy today and put the new top down for the first time. I must have bumped the antenna. It's the standard telescoping antenna from the period, back before the wanted a fixed-length wire for FM performance. Longer was better for AM. But the Chevy's antenna has to be fiddled with. I assume that there are some internal brass/bronze wipers to make contact between sections. Has anybody ever dealt with this?
I'll post some pix of the top-down clean Chevy when I get home.
Car radio antennas
Re: Car radio antennas
We used to keep power antennas working nicely by spraying some WD-40 on a rag, fully extending the antenna, then wiping the mast with the WD-40. Cycle the antenna two or three times afterwards. Not only would this keep the antenna from sticking in a position, it would help to eliminate the noise and intermittent operation when the elements got some corrosion on them.
I'll try that. It did sit for 35 years, so if I'm lucky it's just a bit of corrosion.
