Should I, or shoudn't I ?
Post: # 5990Post Hi-Fi-Mogul »
I ran across this super cute 1953 V-M 990 Tri-O-Matic
overnite case portable hi-fi.
It is a 2 tube amp w/Se rectifier and a 4" x 6" speaker.
The tonearm has the original Sonotone 2-T cart in it,
and standard 1/2" wide mounting holes.
For 1953, it is cosmetically really nice.
If I win the minimum bid, it will cost me total $35,
including shipment.
I don't NEED another hi-fi, but it is very compact....
I'm eager for the polling results here, ha ha !
V-M 990 1953.jpg (125.08 KiB) Viewed 2399 times
V-M 990 1953-2.jpg (199.36 KiB) Viewed 2399 times
V-M 990 1953-1.jpg (191.72 KiB) Viewed 2399 times
Re: Should I, or shoudn't I ?
Post: # 5992Post TC Chris »
I've never seen a V-M with the amp controls integrated into the changer base like that. And I assume the "two tubes" means a preamp tube before the output amp, a step up from the uber-frugal models like my little RCA with one tube doing all the heavy lifting..
back-2-mono
Post: # 5993Post back-2-mono »
You should!
Post: # 5997Post electra225 »
You should!
Post: # 5998Post walyfd »
It's $35. What have you got to lose? It'll give you more happiness than 7 gallons of gas, won't it?
And It'll still be worth something a month from now.
Post: # 6003Post William »
It's VM, so you should definitely buy it.
Ken Doyle
Post: # 6004Post Ken Doyle »
That little phono is the cat's pajamas!
Post: # 6005Post Hi-Fi-Mogul »
OK, the voting is as the super-cryo-computer predicted.
I'll place the bid tonight.
Here's some info from the Sams.
Looks like servicing the amp will be
a piece of cake !
Post: # 6011Post hermitcrab »
Neat little project
Post: # 6012Post TC Chris »
I don't have my tube manual at hand so i can't calculate... but how much power does that series filament resistor, R12, dissipate? Looks like a little electric heater.
Post: # 6013Post TC Chris »
Oops. I saw the voltage on the Sams. A little over 3 watts to shed as heat. Not bad.
Post: # 6015Post Hi-Fi-Mogul »
TC Chris wrote: ↑Mon Mar 14, 2022 12:43 am Oops. I saw the voltage on the Sams. A little over 3 watts to shed as heat. Not bad.
Chris,
Thanks for the info. It's a 10 watt resistor, so
it should be relatively cool then.
At first I thought it was a vintage USB stick, ha ha !
Post: # 6026Post Firedome »
Love the red hammertone !!
Hot chassis?
Post: # 6035Post electra225 »
Hot chassis. Cute little thing, though. :D :D
Post: # 6044Post Hi-Fi-Mogul »
Bids went above my limit.
I've got two RCA changers to service for customers,
so I'll have some hi-fi pocket money to try again
on something else.
Post: # 6056Post electra225 »
That's too bad. That would have made a nice addition to any collection and was in condition that you don't see that often. Better luck next time.... ;) :D :D
Users browsing this forum: Google [Bot] and 43 guests
