General Electric RC-1674a
halzg
Junior Member
Post: # 30728Post halzg »
Hello, I have inherited a GE RC-1674a mini console. This is the type that can be wall-hung, although this one never was. It was the main stereo in my childhood home, and has been stored in my father's (damp) basement for the past 25 years, unused. I've been checking it over and researching it for a few weeks, and here is what I've learned so far:
The unit powers on and plays. I had not read the warnings about old electrolytic capacitors, but now that I have, I will not apply power to it any more until I have the filter caps in a better state.
The Garrard changer appears to be an Autoslim-P model. It was sluggish but functional when I first brought it home, so I removed the changer and cleaned / lubed the pivots and bearings, and did a mild resurface on the drive wheel, and now it works as it should.
The amp works, it has a light 60 cycle hum. All the inputs work, including the RCA plugs for the tape input. The pots were all scratchy, but have cleaned up with some de-oxit.
Both speakers work and sound decent for their age.
The tuner works but is very difficult to tune and drifts badly. The FM-ATC and FM-Stereo circuits both work. The tuner has a more pronounced 60 cycle hum than the amp alone.
I have the Sams Photofact Set 674 Folder 9, which is for this unit.
halzg
Junior Member
Re: General Electric RC-1674a
Post: # 30732Post halzg »
Here are a few photos of the inside. I've read the advice that the entire electronic assembly should be removed as one, due to the indiviual chassis being hardwired together. I'd appreciate any insight as to how to access the chassis mounting screws for the tuner. It appears to be screwed to the underside of the cabinet top, and the dial is screwed to the cabinet front. There is one screw hidden behind the tuner flywheel, looking in from the back. I'm not sure how to access that.
The amp board shows some darkening around the tube sockets. The board is also flexible enough to make me nervous about breaking traces while removing and installing tubes.
I'm fairly acquanited with tube amps, due to experience with guitar amps. Tuners, however, are a mystery to me.
I've noticed a few other members here either have the same console, or a console with a different cabinet but the same electronics inside.
halzg
Junior Member
Post: # 30733Post halzg »
As it turns out, the screws that look like they secure the tuner dial to the faceplate are adjustable standoffs, so I removed two screws holding the tuner chassis to the top of the cabinet and the whole thing slid back. This after I (unnecessarily) removed a few cabinet screws and took the faceplate off. :? d
Overall the tuner looks good visually. I'll post photos tomorrow and continue working to get the electronics out.
Post: # 30735Post electra225 »
I have a set of those guts upstairs that I took out of an ugly GE console. IT works, pretty well, actually. That amp is found in several GE stereo/record players. I have that amp chassis in an RC-1590 C and I use it more than almost any other stereo record player I own. The amp chassis has a power transformer and single-ended 7189 audio output. Basically souped-up 6BQ5's that are made to run on higher plate voltage than a 6BQ5. I've used 6BQ5's in my GE stereo just to see what would happen. I didn't see any difference. You might want to test or sub tubes in the tuner and make sure the antenna is adequate for your location. Those tuners are not known to drift. They have AFC and built-in stereo decoder, so they were ahead of their time. The amp chassis boards tend to burn around the output tubes and rectifier sockets. This can be remedied if necessary by hard-wiring the PCB with bell wire. I redid one like that in 2014 and it still is going strong. The biggest issue with those chassis is the tone board. They suffer from broken or damaged trace(s) that are nearly impossible to find. The cure is to hardwire the entire board. IF you need to clean the controls, they have to be removed from the board if a "simple spritz" doesn't help. GE made very simple electronics, made to a price point, but are really pretty tough and reliable. They perform above their pay grade.
Post: # 30736Post William »
That big orange electrolytic capacitor that is beside the amp chassis is the first thing you need to replace. Like you, I fired up the one I was servicing for someone just to see what worked. Like you it fired up and played just fine, I did not have any sign of a hum which usually indicates the filter cap is bad. I turned my back for a couple of minutes and when I turned around the rectifier tube was bright red and the PT was so hot you could fry an egg on it. The PT survived but the rectifier tube did not. Be sure to add a fuse as you do your servicing. It will help prevent components from getting fried in case a capacitor shorts out.
Also, if you take a look at your cartridge I bet it will be a GE100, that is what was in the one I serviced and is in a GE portable I have.
Thanks for sharing the photos, we love photos. :)
halzg
Junior Member
Post: # 30741Post halzg »
Thanks all for your help and for following along. Here's the state of affairs today:
The electronics are on the bench, visually everything looks okay, nothing is visibly burned or damaged. My next step is to get some electrolytics to replace the cardboard filter cap. Is it coincidence that it looks like a huge firecracker?
I've read that the selenium rectifier on the tuner board should also be assumed bad (besides the electrolytic caps on the tuner). Is that the consensus here?
Also, I do not plan to re-stuff the cardboard filter cap. Since it has long leads, my thought is to clip those close to the cap, then use them to connect to new Electrolytics, which I can mount on a terminal strip at the location where the bracket for the cardboard cap was. I know it won't look original, but are there other concerns with that arrangement?
Thanks to all,
Hal
halzg
Junior Member
Post: # 30742Post halzg »
Here's another photo of the tuner board, that shows the rectifier and the filter cap.
Post: # 30744Post William »
The PC board around the output tube sockets looks typical for vintage PC boards. And, as far as I am concerned, and that is what I did on the one I serviced, use the long wires, terminal strip, and attach the new electrolytic capacitors. I would also do what is necessary for the can cap on the tuner and I believe the consensus is correct with the selenium rectifier. Check your resistors for drift and if there are any, I don't remember that there are, replace all paper caps. And, don't forget to install the fuse. You are making progress, and I hope you are having fun in the process.
Post: # 30747Post electra225 »
You have a later model of that amp chassis, since it had bakelite or plastic tube sockets rather than the older phenolic ones that fried and caused trouble. That would have to be a plus. Have you measured B+ on the tuner chassis with the selenium in place? If B+ is low, that might be a cause for the drifting. I think I'd check that so I'd know where I was if the drift was still there after repair. I would also HIGHlY rocommend replacing both filter caps with 100uf @450 VDC and the cathode bypass cap with 100uf at whatever voltage you have handy above 50 volts. Increasing the output filter cap to 100uf will eliminate the engineered-in hum in that amp chassis. Increasing the capacity of the cathode bypass cap will help enhance bass. Bill's recommended method of mounting filter caps in that chassis is the preferred method. As a wise man once said, "don't forget the fuse"........ ;) ;)
Those amp chassis are known for poor ventilation. When you test the tubes, let them get well warm before you test them. The 12AX7 is especially important. Those tubes run screeching hot, so testing them that was is the only accurate way.
halzg
Junior Member
Post: # 30760Post halzg »
Thanks for the replies!
You answered my next question...I'm having trouble sourcing a reasonably priced 70mfd cap for the cathode bypass on the 7189s, so I wondered if going up to 100 would have an adverse effect, other than increasing the frequency response range. Falling back on my guitar amp experience, a "fully bypassed" cathode isn't always a good thing, since the bass can get loose, but then guitar amps are intentionally pushed into distortion, which is not the goal with a hifi amp.
Noted on the fuse, i'll add one in the AC-in circuit right behind the interlock connector. The whole set is rated for 70 watts max. with the tuner and amp running. No spec is given for the turntable motor. I'm thinking 1.5 - 2.0 amps for the fuse should be about right.
Just so I understand about the selenium rectifier, by checking B+ with the selenium still in place, I'm isolating potential causes of the poor tuner performance, is that right?
Hal
Post: # 30767Post electra225 »
Correct.
Post: # 30772Post TC Chris »
On the fuse subject, remember that the initial current inrush is greater than when operating because the tube filaments are cold and because the filter capacitors are charging. It's why the dim-bulb tester goes bright at turn-on then dims (we hope). Somewhere I saw a piece on calculating fuse size to accommodate those effects. I'll have to look for it. If you have a formula, please share it.
halzg
Junior Member
Post: # 30774Post halzg »
I just used an Ohm's Law calculator, 70 watts @ 117 volts is about 0.59 amps. Doubling that to allow for inrush current gets me to 1.2 amps, rounding up to next common size is 1.5 amps. There is probably a more accurate way to do it, but it's a start.
Hal
halzg
Junior Member
Post: # 31038Post halzg »
So far I have replaced the filter caps and the power tube cathode resistor bypass cap (the three that are combined in the cardboard tube), and added an inline fuse right behind the interlock.
I've reassembled the amp and control board back into the cabinet, and it plays and sounds very nice. The hum is gone, the pots don't crackle, and no smoke came out when I plugged it in.
I left the tuner out, since that will take me a bit longer to diagnose.
A few things I've learned thus far:
The schematics are only partially helpful for wire colors. Not all of them are noted, and even if they are, once you get to a splice, the next wire color is random. It seems as though the factory grabbed whatever wire was handy when they assembled it. At least the transformer tap wires seem to be correct.
The "bread tie" wire retainers seem like a great way to create a short circuit. I'm going to try tacking some plastic wire ties to the cabinet instead.
The factory wire nuts used extensively don't like being re-used.
I'll post photos of the re-assembled unit soon.
Hal
Post: # 31039Post electra225 »
The main challenge to those GE chassis is that the connections in those wire nuts should be cleaned and soldered for reliable service. You won't need to take it apart again in your lifetime and, if you do, just un-solder it and go on. You can use those little plastic loops you can get to hold the wiring if you don't like the bread ties. GE liked those, probably because they were cheap. I don't know that they ever caused trouble, to be honest. The output tube sockets and output tubes you showed look like they have had a hard life. The board has been hot, a lot. Carefully clean the tube socket connections and also check to see there are no burnt and "almost broken" traces in that area. I don't intend to preach, but I've been kicked by that mule before! The tuner chassis doesn't eat as much heat, so they don't usually cause much issue. IF you controls and function switch are good, make good contact and no noise, you should be golden there. Check to see that B+ in the tuner chassis is close to right on the money. Those GE chassis are of minimalist design, but they sound surprisingly good, particularly that chassis. If you need output tubes, JJ 6BQ5's should work just fine. I'm a fan of matched output tubes, but I don't know if they would make that much of a difference in single-ended service. Sounds like you are making good progress, so good luck with your project.
halzg
Junior Member
Post: # 31043Post halzg »
The factory splices are interesting. The wire ends appear to have been tinned, then twisted, then the wire nuts installed. It would have been simple to have soldered them, since they were already tinned, but no. I will solder them once I'm sure everything is in good order and I don't need to pull anything back out.
I did clean the sockets and pins on all the tubes, and in spite of the browning around the tube sockets, I didn't see any cracks or other distress in the substrate or the traces. The old tubes seem to work fine, so i'm going to ride them until they quit.
Hal
