New here, but not new to vintage radios
BSMet94
Junior Member
Post: # 30487Post BSMet94 »
Hi,
Joined here after searching the internet for info on my newly acquired Magnavox console, for which I'm gathering information to restore. It's a 1ST288G, Micromatic changer, AM/FM Stereo, 8801-20 Amp, haven't pulled the preamp yet to get the stamp on that (probably 59-something). Just blowing out the dust and counting capacitors, etc. right now. I'll post some stuff later when I start into this.
Already finding lots of good info here!
This is sort of my first HiFi project. I've restored a late-40s Motorola AM/SW radio, and a late 30s Packard Bell, so my soldering skills should be up to the challenge.
Eric
Re: New here, but not new to vintage radios
Post: # 30488Post electra225 »
Welcome aboard, Eric! And thank you for completing your registration. I have six Magnavox stereos, all with P-P amps, two with the 88-series amplifiers. Lots of room to work, pretty straightforward. Recommend matched output tubes. Be sure to check the 220K ohm grid resistors, usually found drifted wildly high. Check really carefully (or just change) the cathode bias resistor, they are known to be burned internally. If it fails, it can cause damage to the output transformer, something you don't want. They are "Magnificent" instruments, best there was in their day. Good luck with your project, feel free to ask questions and don't forget to take and share pictures!! ;) ;)
Post: # 30490Post William »
Hello, Eric, and welcome to our forum. Lots to read and lots of help for the asking and like Electra 225 said, please take photos to share as you start your project. And, I want to thank you as well for completing your registration, you have no idea how many just kind of ignore that part of joining up. One last thing, please provide an Avatar when you get one picked out, that is the final part of registration.
Thank you,
Post: # 30492Post TC Chris »
SEnd photos of all the projects!
BSMet94
Junior Member
Post: # 30493Post BSMet94 »
Thanks for the welcome messages. I will start a thread in the Magnavox section on this one. Glad to be here!
Eric
