Mustang TFI
Mustang TFI
Tonight's project: installing a remote, heat-sinked location for the Mustang's "TFI" (thick-film ignition) module. The TFI is a known failure point for Fords of that era. Ford saved a couple pennies per car by locating it on the distributor, on top of the engine, a place where its subjected to high heat. And guess what high heat does to the TFI? They designed it to survive the warranty period. My first one failed in about 1995. The engine just stopped as I was driving. Well, last fall, last drive before storage for the winter, the engine stopped as I was driving. That time it restarted but it doesn't do much for confidence in the reliability of the vehicle. I ordered a relocation kit from Jason McCully. So tonight I was out drilling holes in my Mustang to mount the heat sink. Ouch. My 1960s vehicles have enough room under-hood to set up housekeeping or stretch out for a nap, but by 1986 things were getting crowded.
Next is to rotate the distributor to get access to the screws for the old TFI. The video says to mark it before rotating and then set it back to the mark. Seems like maybe it would be wise to check the timing. I've never timed the Mustang. It's electronic and stable. I have a couple good old timing lights from breaker point days, but wonder if they'll handle the higher ignition voltage of newer vehicles? Any experience, good or bad, with that?
I'll need to consult the shop manual for timing conditions. No vacuum advance line to plug on this one, and no mechanical centrifugal advance to worry about. Any experience with timing EEC-IV Fords?
Re: Mustang TFI
My experience with Ford TFI and also the older Thunderbolt ignition has generally been good. The TFI that mounts on the distributor is probably the better of the two systems as far as reliability is concerned. Secondary ignition condition, plugs, plug wires, distributor cap and rotor are critical for long life and reliability in that system. The GM HEI system and the newer C3-I systems were almost bulletproof. I found it critical to use genuine Motorcraft igniton modules in the TFI systems. Not only do the aftermarket modules fail more often, they can also mess up other systems, such as injector "on times". If we were investigating a weird or intermittent driveability issue in a Ford with TFI and found an aftermarket ignition module, that was our first avenue of investigation. I kept a known-good Motorcraft TFI module in my tool box for substitution testing in such cases.
Re: Mustang TFI
Apparently the good Motorcraft modules are unobtanium now. The current ones are not reliable, and the aftermarket brands are superior.
The problem was just poor design, putting the modules in a location where excessive heat kills them. There was a big lawsuit and that's where they discovered that Ford knew the devices would fail--shortly after warranty ended. It was a purely cost-related design decision.
Re: Mustang TFI
The 5 litre Mustang guys ran high energy aftermarket ignition systems back in the day, I believe made by Mallory. I had one in the shop that had punched through the insulation of the stock plug wires. They had to run spendy wires made to handle the high voltage.
Re: Mustang TFI
The night before last, I installed the last step on the TFI relocation project--the dummy TFI on the distributor, with wires from it running to the new TFI on the heat sink. It took 3 hours in heat & humidity. Lots of @#%**$!!!. The online video makes it look like a half-hour job, but that must have been on a truck engine. On the Mustang, there's plumbing and brackets in the way. Couldn't even hold a Sharpie right for the distributor timing mark--took 3 ties. No room for the hands to hold the device and turn the tiny Allen wrench. When I was done I was too tired to drive, and besides, I did not want a disappointment. Last night I went sailing after work and then came home, rolled the Magnavox out of the way, and turned the key.
After 8 months in storage, it started on the first crank. Not a single miss. It always missed for 5 or 10 seconds after storage. I didn't even get the clutch chatter that usually showed up on the first two or three engagements. Drove around town, stop and go, and the 7 miles down the highway and back. No problems.
If you've got a Ford with the notorious TFI, I endorse the McCully Racing Motors kit and the Accell aftermarket TFI module.
Re: Mustang TFI
Congrats on a successful retrofit. The distributors with breaker points benefit from the installation of an Ignitor to replace the points. I've heard you can't buy dependable breaker points currently. Nobody is putting any R&D money into a technology that essentially went obsolete over 50 years ago. Next up will be carburetor rebuild kits....
Re: Mustang TFI
It's wonderful not having to deal with that TFI crappiedaux any more. Whoever started the instruction to use dielectric grease on the module instead of thermal heat sink compound to mount the module had to hate mankind.
Re: Mustang TFI
The kit came with dab of gray thermal grease and instructions to treat it carefully because it's so expensive to replace. I kept getting my finger in it as I was unboxing/exploring. The Accell TFI came with a tiny packet of white grease that I have saved for future use. Hope it won't be needed but I will carry the old module in the car, just in case, along with the Allen wrench for the new screws ( no special tool required). I'll get a photo of the big new heat sink soon.
Re: Mustang TFI
The white grease contains finely ground epsom salts. It' best to apply it with a razor blade to get a thin layer. Some make the mistake of applying a thick layer on it. It is only to fill the minute imperfections in the metal's surface to provide effective heat transfer. Now, if one was to mount the module to the distributor's housing, it would seem that the heat transfer would be from both the housing with the engine's heat and the modules' internally generated heat. Add this little fact into the mix: All of the more recent modules were assembled using lead free solder that softens and melts at a much lower temperature. Conventional mounting is a failure waiting to happen.
Re: Mustang TFI
The new heat sink. Yes, the engine is dirty.
The new TFI module is behind the fins. The shiny woven cable connects it to the distributor.
Re: Mustang TFI
That's just about the same place the factory TFI was mounted in my '94 GT.
Re: Mustang TFI
electra225 wrote: ↑Fri Jun 26, 2026 11:42 pm The GM HEI system and the newer C3-I systems were almost bulletproof.
I found you can now purchase the GM HEI system in an after market distributor of almost any make of engine. I purchased one for a Ford 302 and even found they had one for the old 292 Y-block.
Re: Mustang TFI
An HEI distributor from a 350 or 455 Buick will fit in the engine of my old '63 401. But the body of the distributor is so large, there isn't enough room between the air cleaner and the air conditioning plumbing for it to fit. So an Ignitor is what I used. The tractor pull guys are using six-cylinder Chevy HEI distributors in their six-cylinder gas engines. Chrylser flatheads and Olivers are the biggest beneficiaries, but will also work in IH. Anything that had a Delco distributor originally. I didn't know they were using them in Fords. You used to be able to buy really hot coils for a GM HEI setup that would melt spark plug wires....
Re: Mustang TFI
Took the first road trip in the relocated-TFI car. 145 miles at highway speeds in a 40 year old vehicle. No problems!
Re: Mustang TFI
That should put paid to TFI problems from here on out.
Re: Mustang TFI
The Mustang made it around town at the other end and then home again too for a total of about 300 miles over a three-day weekend. But when I posted the photo of the TFI relocation, I realized how dirty the engine compartment was. So I washed it. In years past, I would knock on doors for local candidates. Before I left Lansing, I think I had knocked on every house in the city. Then I'd go home and clean up my front porch after observing how often they are neglected and how bad it looked to visitors. Sometimes you need perspective....
Re: Mustang TFI
Washed the Mustang for the first time in at least 2 years. It had been raining often when I was driving it more. Now with the TFI upgrade I'm driving it more. Washed the Chevy last weekend and decided to do it to the Mustang last Sunday, after verifying that there would be no rain until I got it home.
Re: Mustang TFI
There is nothing nicer than a clean vehicle.
Re: Mustang TFI
A shiny one is even better!
