VM-560A Mechanical Click
Akron70
New Member
Post: # 29891Post Akron70 »
Hi All,
I am new to the forum and need some help. I just recently restored a Voice of Music 560A record player. Everything works correctly except that I get a mechanical clicking sound (sometimes it double clicks) as the platter turns. The sound usually starts around 20 revolutions into playing a record. The clicking sound will sometimes disappear after it starts and then reappears after about 4 revolutions. It comes and goes. I'm sure the sound is mechanical, not electrical.
Any idea what is causing this? I'm hoping I don't have to tear it down before I know what I'm looking for.
Thanks for any help!
Re: VM-560A Mechanical Click
Post: # 29892Post electra225 »
Welcome to the forum! You have come to the right place for information on your VM changer. My first guess would be that your noise has something to do with the drive tire. Something stuck to it, maybe it has a flat spot that makes more noise some times than others. I'm sure someone else will chime in, hopefully with the cure. Welcome aboard, thank you for completing your registration. We hope you will enjoy the forum!....... :D :D
You posted this topic twice. I deleted the post in Getting Started. Members will see it here and will be more than happy to help....
Post: # 29893Post TC Chris »
A wild guess--the trip mechanism getting bumped?
Post: # 29894Post electra225 »
Or maybe a dry bearing under the platter? Has this changer been tuned up? Old grease removed, new grease installed, new motor mounts, rebuilt drive tire? What is the tone arm pressure?
Post: # 29898Post Hi-Fi-Mogul »
Welcome to the forum !
The V-M 1200 changer motor and cycling mechanism
will need to be dis-assembled, cleaned well,
and lubricated only in appropriate locations.
Then, if the problem persists, you've done the
service, and the problem is easier to define.
There are numerous good videos on this process.
Part 1 of Chris Cuff's (RIP) series in link:
https://www.youtube.com/watch?v=RZffuxl9bB0
The V-M 1200A changer manual is is the downloads sections.
