Philco 46-1203
Philco 46-1203
Got this beautiful Philco 46-1203 from my mom! She found it at the same place I found the floor model Philco last month. It will need a new power cord, caps, ect, as these always do. Thanks mom!
Re: Philco 46-1203
I have seen that model, or at least one that looks like yours, at estate stales, antique stores, or auctions. I always thought they were nice looking and if the radio plays like most Philco's it should work great.
Re: Philco 46-1203
This also could be a Philco 48-1256, I need to check again.
Re: Philco 46-1203
I had two 1203's. They are good performers as far as the radio goes. They use the D-10 changer, not one of Philco's best, IMHO. Easy to work on. Good luck with yours!
Re: Philco 46-1203
I've got a 46-1203. It was in my grandparents' house, parked next to a bed in the guest room where I'd sleep when visiting. I'd turn it on at night, enjoy the warm dial glow, and experience the miracle of hearing sounds coming through the air. Then it started humming. I did rescue it when we closed the house out. I should recap it. I see it has an RF amp but otherwise is unremarkable. One of those switched hi-filter tone controls.... Yeah, that changer looks like nothing special at all.
Re: Philco 46-1203
Well it’s a good thing 78s are my favorite type of record to collect!TC Chris wrote: ↑Tue May 19, 2026 3:26 am I've got a 46-1203. It was in my grandparents' house, parked next to a bed in the guest room where I'd sleep when visiting. I'd turn it on at night, enjoy the warm dial glow, and experience the miracle of hearing sounds coming through the air. Then it started humming. I did rescue it when we closed the house out. I should recap it. I see it has an RF amp but otherwise is unremarkable. One of those switched hi-filter tone controls.... Yeah, that changer looks like nothing special at all.
Re: Philco 46-1203
I've got 78s too, and the really old ones are beat-up enough not to worry. The better, newer ones are capable of much better fidelity than that Philco would deliver, and it would be grinding them up the way the old Sonora acoustic device does.
Re: Philco 46-1203
The Magnavox TP 241 I redid plays 78 very nicely. It has a ceramic cartridge, diamond needle, tracks at five grams, feather-weight for playing 78's. The fidelity of the later 78's that were recorded on tape is every bit as good as the later LP's that replaced them.....
I have long maintained that the fidelity of 78's in good condition was better than that of 45's in similar condition. I've never played a 78 on a "modern" turntable with a super-light magnetic cartridge. I've always want to try it....
Re: Philco 46-1203
Well this certainly has taken an unexpected twist! I went to my mom’s house to check to model No. And it turns out I have a 48-1256!
Re: Philco 46-1203
I think that means you have a 1948 instead of a 1946. The tubes appear to be the same so I am not sure what the actual difference would be other than model number.
Re: Philco 46-1203
In theory, faster speeds are capable of higher fidelity, especially at higher frequencies. In practice, 78s were typically pressed on shellac with noisy filler, and recorded on the assumption that none of the playback equipment was capable of reproducing high frequencies anyway.electra225 wrote: ↑Thu May 21, 2026 2:51 am The Magnavox TP 241 I redid plays 78 very nicely. It has a ceramic cartridge, diamond needle, tracks at five grams, feather-weight for playing 78's. The fidelity of the later 78's that were recorded on tape is every bit as good as the later LP's that replaced them.....
I have long maintained that the fidelity of 78's in good condition was better than that of 45's in similar condition. I've never played a 78 on a "modern" turntable with a super-light magnetic cartridge. I've always want to try it....![]()
Another twist on it is that 78s were recorded with different equalization standards, and most modern equipment with magnetic cart preamps uses the RIAA curve. Some older tube equipment had other equalization choices. My Maggie Provincial Serenade and my Bogen DB-115 have a "78" setting on the preamp. I think both have "Col" (Columbia), for those early LPS and "Eur" or European.
Re: Philco 46-1203
I think Bill hit this one out of the park. My two 1203's were 1946 models. The tubes in yours are the same as in the 1203.
Re: Philco 46-1203
My Magnavox Berkshire has all of the equalization settings. RIAA, LP, 78, and EUR. Playing a 33 (LP) record and selecting the different equalization setting you can hear the frequencies change, mostly adjusting the mid to upper range.
Re: Philco 46-1203
I got it with me right now. The turning dial doesn't move the needle even though the stings are not broken...I have a Zenith Transoceanic with that issue. I was gonna get a look at the bottom of the chassis but while taking it out my FOMU kicked in worried I'll ruin something in the process of getting out of it's place (like breaking the dial string) I put it back!
I had too many "fiddled with it until I broke it" moments!
I'm definitely more of a wind up phonograph person! lol.
Re: Philco 46-1203
The chassis on that set is kinda tricky to extract from the cabinet. The dial glass is in the cabinet, rather than on the chassis. The chances of you breaking it extracting the chassis are minimal. More of a chance doing damage going back in if you don't mind the shafts sticking out of the chassis. IIRC, laying the cabinet on its side (protected by putting a towel under it) seems to have been the better way to extract the chassis. Just be careful and you should be fine. The side where the chassis is on the top is the way I did it. There are two screws on the side that hold the chassis in.
