Now here's a record player even I can work on! 😃
1922VV111
Full Member
Post: # 29369Post 1922VV111 »
I found this at the same swap meet as the Philco. This 1909 Edison Standard D cylinder player needs a new mandrel bearing to run again! The original is made of swollen pot metal preventing the motor to spin and play a record. This contains no dangerous electronics that will zap me if I make a wrong move! This is something i'm confident on working on myself!
Re: Now here's a record player even I can work on! 😃
Post: # 29378Post TC Chris »
Mine's also a D but a different configuration (newer?). See my YouTube video of it here:
https://www.youtube.com/watch?v=g-n4MC4u8aA&t=191s
I'd like to get a 4-minute reproducer. Sources? And mine probably will need a belt soon.
1922VV111
Full Member
Post: # 29382Post 1922VV111 »
TC Chris wrote: Sun Apr 19, 2026 3:26 am Mine's also a D but a different configuration (newer?). See my YouTube video of it here:
I see yours is a Home model, I have one of those too. I have a few Model H reproducers that came from other machines I have. I sometimes use Ebay or the Yankee Trader section on the Talking Machine Forum. For Belts on a Edison standard I use a GE O-ring for a water filter. Iv'e have machines I did with the O-ring years ago and still play and track fine. I absolutely HATE those leather belts!! I've ALWAYS screw them up when trying to make them! :evil:
Post: # 29386Post TC Chris »
Why did Edison make so many different models?
danrclem
Post: # 29389Post danrclem »
I have one (can't remember which model) and it has a device that makes it play the song again. I'm not sure if it's all there though.
1922VV111
Full Member
Post: # 29398Post 1922VV111 »
I have gotten all of the old pot metal mandrel bearing chipped away BUT the upper pulley and mandrel gear are COMPLETELY frozen to the mandrel shaft. I tried oil, PB blaster, etc and they are Not freeing up so I'm gonna try and use my soldering iron (yes I bought a new one but it's a cheap one) and if that doesn't work, I got a butane torch that will hopefully melt all the old grease thats keeping this stuff stuck.
Post: # 29400Post William »
Before you directly apply heat try a hair dryer on the highest setting. I am not a fan of direct heat, touching something, but have had really good luck with a hair dryer. Don't be afraid of getting it HOT, like hot enough you shouldn't touch it. Then if that does not work...
1922VV111
Full Member
Post: # 29656Post 1922VV111 »
I got the last two pieces I need to get this phonograph working again soon! WOOHOO!🙌 The belt and upper pulley!
1922VV111
Full Member
Post: # 29845Post 1922VV111 »
1922VV111 wrote: Sat May 23, 2026 11:29 pm I got the last two pieces I need to get this phonograph working again soon! WOOHOO!🙌 The belt and upper pulley!
Sadly the upper pulley never came, and the seller has not responded to my messages. Instead of ghosting your PAYING customers at least inform there will be a delay! :evil: :roll:
Welp. I'm gonna get my 33 bucks back and the seller a rare negative mark from me...
Post: # 29847Post TC Chris »
What is the problem with the upper pulley?
